Can the offset of a 1 piece wheel be changed safely?
A friend of mine has some Team Dynamics wheels sitting in the garage. The fronts are a +40mm offset and the rears are +18mm. They are all 15x7s but I need to have all four at +40mm. Can a machinist take out 22mm of offset without causing structural issues?
These are from his track car and will be used on my daily driver.
-Jess |
It's impossible to tell without knowing more about the wheel, but I seriously doubt it. 22mm is alot of material.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
How much metal do you have between the bottom of the lug nut taper or ball fit and the back side of the well? As long as you have about 1/8" thickness at the ID of the stud hole after machining, you should be fine.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
