Almost Banned Once
sc_rufctr's Avatar
Ratchet Spanners (Wrenches)
They look cool but overrated IMO.
- Peter
Old 10-19-2020, 01:25 AM
I have never used one, I use a series of Craftsmen collections that I have had for 40 years, and have never found the need for these. Constantly doing tractor, home building, and car projects.
Old 10-19-2020, 02:33 AM
Retired, finally
SiberianDVM's Avatar
Every now and then they come in handy where there is not enough room for a conventional ratchet and socket.
And so far, the 10mm has not run away from home.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 10-19-2020, 03:23 AM
Brew Master
cabmandone's Avatar
No way are they overrated IMO. I break mine out almost every time I need an end wrench. About the only time I don't is when a bolt or nut is too tight. I have the more conventional styled offset box end and mine have reversing levers so you don't have to flip the wrench to tighten or loosen.
You should box that set up and send them too me!
Nick
Old 10-19-2020, 04:28 AM
Hell Belcho
Nostril Cheese's Avatar
Most useful tools I own. Save so much time with them.
Old 10-19-2020, 04:45 AM
Still Doin Time
asphaltgambler's Avatar
They have their place...I own both SAE & Metric sets
Old 10-19-2020, 04:49 AM
I have 2 sets (SAE & Metric) like this, and they are fantastic. They don't replace a ratchet and socket set, but they are a fantastic tool to have under certain circumstances.
Old 10-19-2020, 05:01 AM
fastfredracing's Avatar
Yep, one of my favs. Swivel head.
No left turn un stoned
Old 10-19-2020, 07:21 AM
My set occupies a space right next to my open end wrench set in the drawer just below the drawer with the normal set.
Edit -they weren't in the same drawer. Old age, been a while since I've been in my tool box.
Scott
'78 SC mit Sportomatic - Sold
Old 10-19-2020, 07:58 AM
I have a bunch of them as well. The swivel head are really useful as others have mentioned. I have an older Craftsmen set that has a socket that fits in the wrench and is very low profile.
Old 10-19-2020, 08:18 AM
Shaun @ Tru6's Avatar
I have 2 sets metric. one normal and one with the hinge wrapped with electrical tape a few times around. Still flexes but isn't as free as the normal hinge which helps in some situations.
Great tools.
Tru6 Restoration & Design
Old 10-19-2020, 08:25 AM
Ratcheting box-end wrenches are fantastic. I found them after replacing a water pump on one of my cars (thanks, FWD) where I had about 1" clearance between the pulley bolts and frame rails, and spent forever and a half getting the pulley off with a regular open-end wrench.
'80 SC Targa
Avondale, Chicago, IL
Old 10-19-2020, 08:28 AM
Information Junky
island911's Avatar
Agree. Unless they are switchable, they can end up stuck.
Old 10-19-2020, 08:30 AM
These are often the first thing I grab.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-19-2020, 08:38 AM
Friend of Warren
Usuallly these are the first ones I grab.
Kurt V
Old 10-19-2020, 08:48 AM
I use mine a lot. There are times they are the only way to get a nut off or back tightened down without spending forever turning a open end 1/4 turns at time.
I too have a set of fixed end and swivel ends in both metric and SAE. But I am a self confessed tool junkie.
Old 10-19-2020, 08:49 AM
This is one case, where generic are just fine in lieu of Big dollar snappies.
I think I have one set of Blackhawk, and one set from Gearwrench. Both are fantastic, the only ones I have ever had to replace are the ones I lost . They are not for breaking fasteners loose, just winding the out .
Old 10-19-2020, 09:25 AM
Those and my Milwaukee 9 volt electric ratchet gets regular use. Recently I removed the seat on my 911. Those Allen bolts are a tedious with a regular ratchet. The battery operated ratchet makes it easy.
Old 10-19-2020, 09:41 AM
I have Crafstman, Gearwrench and some other no name brand. Have never broken one either.
Old 10-19-2020, 10:04 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I use them frequently. I only have a couple types, nothing fancy. Oh, and a set of metric stubbies. I like the fixed angled head ones best. I don't care for swivel head tools unless mandatory.
1981 911SC Targa
Old 10-19-2020, 10:14 AM
