Banned
waves shaking on a computer monitor
my computer just got waves and shaking on the monitor
tried a different monitor same result
tryed reloading the ATI driver pack it got worse
dumped everything in the V driver and reloaded still bad
tried high and low rez and refresh rates
high on both looked worse to the point of being unreadable
with lowest rez best but still some waves and shaking
restore to an earlyer date some what better but still there just somewhat less
the box is a A64 in a MS7093 MB with on board ATI xpress 200 V chip
run avast anti-virus maliwarebites spybot adaware combofix and no cure
is this a known bug or is it chip failure
would a video card be a fix to disable the on MB video chip
edit googled this a bit and common fixes like el wires or magnets near screen DONOT APPLY
no close source of this problem and no thing new has been added or moved
you guys got any ideas
Old 05-02-2009, 03:15 PM
Boot in Safe mode. That will bring up the default, 640x480 resolution. If the picture is stable it must be the video card died and can't run the higher res. You might try a different refresh rate at the higher resolution just to see if it changes anything.
Old 05-02-2009, 03:22 PM
one of gods prototypes
bell's Avatar
there's a lot of decaffeinated brands on the market that are just as tasty as the real thing.
Brought to you by Carl's Jr.
Old 05-02-2009, 05:03 PM
