Registered Cruiser
Boat guys - Overheating problem
I have a 31' boat with twin 7.4 liter Mercs. The port side motor runs significantly hotter than the SB side. 160 deg VS 190. at a constant 3100 RPM
I have recently done the following: cleaned out the intakes (they were pretty gummed up - engine ran 205 degrees prior to cleaning) new impellers cleaned risers checked thermostat Not sure what to do next. Here is a picture of the old girl.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. Last edited by jorian; 06-24-2009 at 03:22 PM.. Reason: more info |
Banned
I/O drives? counter rotation?
equal water flow out? [I bet not !!] you did reverse the impeller on the non-standard motor? remember if it runs backwards the pump needs to run backwards too |
Registered Cruiser
Thanks for the reply.
Boat has I/O with counter rotating props. I guess I would have to check the water outflow with the boat out of the water? Not sure about the reversing the impeller... I'll check on this.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
I dont know power boat engines, I'll ok with sailboat engines. Have you flushed the block? Vinegar does wonders.
Also, any chance the hot engine is lean? Clogged jet/injector? |
Registered Cruiser
I know a guy that tried to run a car carb on his boat. Even with the fattest jets it melted the pistons. Make sure it's setup right.
MBruns for President
Check the sensors too - they are famous for being off on the mercruisers. That said - I'd check mixtures first. Sea Ray?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Unoffended by naked girls
Impellers are just those rubber-vane guys, right? No right or left when new..
So Bravo3 drives? Didn't say where you play, lotsa sand? I/O's are sand vacuums. Pretty easy to pack a motor full... Pull some of the block and manifold drain plugs and poke a screwdriver up there, any exhaust restrictions?
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Registered Cruiser
The mechanic is going to look at the mixture today. Not sure where the sensors are but I'll ask him about these too. The boat is a Formula.
Impellers are indeed those rubber vaned deals. No sand where I am. Thanks again.
Sensors are on the thermostat housings - at least they are on the 5.7's, I'd also pull your hoses - as I had one that put on that was an auto 1" hose that had partially collapsed - and gave me about the same temp difference.
How about heat exchangers? When were they replaced? or cleaned? You can get them cleaned at a radiator shop - you can also run white vinegar through them that will remove some of the scale. I'd get em cleaned or replaced if they haven't been lately (last 5 years) Nice looking boat.
