Registered Cruiser
jorian's Avatar
Boat guys - Overheating problem
I have a 31' boat with twin 7.4 liter Mercs. The port side motor runs significantly hotter than the SB side. 160 deg VS 190. at a constant 3100 RPM
I have recently done the following:
cleaned out the intakes (they were pretty gummed up - engine ran 205 degrees prior to cleaning)
new impellers
cleaned risers
checked thermostat
Not sure what to do next.
Here is a picture of the old girl.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 06-24-2009, 03:09 PM
Banned
I/O drives? counter rotation?
equal water flow out? [I bet not !!]
you did reverse the impeller on the non-standard motor?
remember if it runs backwards the pump needs to run backwards too
Old 06-24-2009, 03:25 PM
Registered Cruiser
jorian's Avatar
Thanks for the reply.
Boat has I/O with counter rotating props.
I guess I would have to check the water outflow with the boat out of the water?
Not sure about the reversing the impeller... I'll check on this.
Old 06-24-2009, 03:42 PM
VincentVega's Avatar
I dont know power boat engines, I'll ok with sailboat engines. Have you flushed the block? Vinegar does wonders.
Also, any chance the hot engine is lean? Clogged jet/injector?
Old 06-24-2009, 04:50 PM
Registered Cruiser
jorian's Avatar
Co-incidently one of the carbs was rebuilt recently - I'll check with the mechanic.
Old 06-24-2009, 04:53 PM
I know a guy that tried to run a car carb on his boat. Even with the fattest jets it melted the pistons. Make sure it's setup right.
Old 06-24-2009, 05:50 PM
MBruns for President
JeremyD's Avatar
Check the sensors too - they are famous for being off on the mercruisers. That said - I'd check mixtures first. Sea Ray?
Old 06-24-2009, 06:02 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Impellers are just those rubber-vane guys, right? No right or left when new..
So Bravo3 drives?
Didn't say where you play, lotsa sand?
I/O's are sand vacuums. Pretty easy to pack a motor full...
Pull some of the block and manifold drain plugs and poke a screwdriver up there, any exhaust restrictions?
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 06-24-2009, 06:24 PM
Registered Cruiser
jorian's Avatar
The mechanic is going to look at the mixture today. Not sure where the sensors are but I'll ask him about these too. The boat is a Formula.
Impellers are indeed those rubber vaned deals. No sand where I am.
Thanks again.
Old 06-25-2009, 09:36 AM
JeremyD's Avatar
Sensors are on the thermostat housings - at least they are on the 5.7's, I'd also pull your hoses - as I had one that put on that was an auto 1" hose that had partially collapsed - and gave me about the same temp difference.
How about heat exchangers? When were they replaced? or cleaned? You can get them cleaned at a radiator shop - you can also run white vinegar through them that will remove some of the scale. I'd get em cleaned or replaced if they haven't been lately (last 5 years)
Nice looking boat.
Old 06-25-2009, 09:50 AM
