cel cel is offline
Generating electricity
Not being very knowledgeable in the subject I will ask the experts. Would it be economically feasible to generate enough electricity for a small house in the Houston area using the earth as a heat sink and solar panels as a heat source with propane as the transfer medium. A piston type motor would drive the generator.
Old 06-28-2009, 03:52 PM
You need you a Gererator.
Old 06-28-2009, 04:03 PM
jyl jyl is online now
jyl's Avatar
No idea - sounds pretty experimental, yes? Solar PV panels and solar water heating, that would be the proven technology.
Old 06-28-2009, 04:17 PM
Detached Member
Hugh R's Avatar
Not sure what you're getting at. Are you talking about heat transfer of fluid? How would the piston move? Look up on wikipedia and search for gas refrigerator and tell us if that is what you're thinking about. I wouldn't use propane for a transfer fluid for anything.
Hugh
Old 06-28-2009, 04:47 PM
AutoBahned
RWebb's Avatar
"generate enough electricity for a small house in the Houston area"
No. Unless you plan to suffer along w/o a/c. People survived that way long ago - does not mean it is fun.
You could put up a bunch of PV panels, collect a govt. subsidy to help w/the cost; feel good about it; and sell to the elec. co. or keep the watts on site... it would likely be "booster power" not handle all your needs.
that would help quite a bit but not pay for itself over 10, or even 20 years.
Now if you wait 10 years, we will likely have some nice cheap PV panels out there... it's all relative.
Old 06-28-2009, 04:52 PM
cel cel is offline
Operation
The solar panel would vaporize the propane and the increased volume would drive the piston motor thereby driving the generator. The motor would exhaust the gas and the gas would be pushed into the earth cooling piping to condense the vapor back into a liquid. There would be a check valve to force the flow in one direction.
Old 06-28-2009, 04:57 PM
Detached Member
Hugh R's Avatar
You'd want a series of successively smaller pistons to claim the rest of the enthalpy.
Hugh
Old 06-28-2009, 05:06 PM
cel cel is offline
Re.: Operation
I believe the mechanical operation will work. I have read the earth has a constant temperature below a certain number of feet and all of this varies with the area of the country. Around Houston it is supposed to be some were about 55-60 degrees below 4-5 feet but I am not sure.The information I am lacking is the amount of piping in the earth to condense the vapor continually and the amount of solar panel area to absorb the required BTU. The propane would be at the required vapor pressure to operate within this temperature range.
Old 06-28-2009, 05:13 PM
cel cel is offline
Re: Hugh R - the would work like steam engines with variable diameter pistons for the same reason.
Old 06-28-2009, 05:16 PM
Information Junky
island911's Avatar
Texas certainly does have a good environment for solar
Typical solar-to-electric power plants require 5 to 10 acres for every megawatt (MW) of generating capacity. A 200 MW solar plant in West Texas would need about 1,300 acres of land.
more...http://www.seco.cpa.state.tx.us/re_solar.htm
...but you need lots of area and lots of equipment.
Old 06-28-2009, 05:38 PM
Detached Member
Hugh R's Avatar
Yeah, if you want to use something really dangerous, like propane, why not just go for anhydrous ammonia? That's what commercial refrigerator used to use, they may still.
Hugh
Old 06-28-2009, 05:42 PM
cel cel is offline
Propane - dangerous
Propane would be dangerous to use in a home or car AC due to the location of an ignition source but this system would be away from any ignition source and I do not think there would be that great of volume. It is also cheap and plentiful (relatively speaking).
Old 06-28-2009, 05:57 PM
Information Junky
island911's Avatar
Propane .... It is also cheap and plentiful (relatively speaking).
which begs the question; why not just burn it for energy?
Old 06-28-2009, 06:04 PM
cel cel is offline
RE: The propane would be used much like a refrigerant, it would not be burned.
Old 06-28-2009, 06:22 PM
Unconstitutional Patriot
turbo6bar's Avatar
Depends on your definition of "enough electricity." With no modern appliances, you may barely make the mark.
I ran the numbers for using a small Lister diesel engine, biodiesel, and a generator for making electricity. The expense, complexity, and labor lost out to grid power at 11 cents/KW. I also considered buying an outhouse and diesel fired boiler to heat water and my home. Despite cost savings using homebrew biodiesel, it still could not match the cost of natural gas.
Sure, if I was off-the-grid, it would be more attractive, but I was faced with sacrificing time for no cost savings. Hard to justify the investment with infinite payback time.
The problem I see with your idea is you'd need significant pressure to move that piston. Or, you could make the piston larger, but then you'd need more vapor. More vapor = more solar panels. Your theory is very similar to solar vacuum tubes used for water heating. The tubes are placed under vacuum to minimize heat loss and increase efficiency. The medium is vaporized by the heat of the sun. The vapor rises and condenses on a manifold at the end of the tube. That heat is eventually transferred to water. Solar water heating should receive greater focus in America. It's proven, efficient, and can immediately reduce energy usage, particularly in the sunny Southern US.
Old 06-29-2009, 05:25 AM
abit off center
cgarr's Avatar
Just tap in before the meter
______________________
Craig
G2Performance
Old 06-29-2009, 05:48 AM
I was curious about geothermal heating and cooling, so I did a little research (I did say 'a little'). I saw/heard/read someplace that Houston would be a hard place to manage it because of the heat. I know that my tap water comes out of the ground at over 80* during the summer. I think you'd need a lot of pipe, and it would have to be fairly deep.
Old 06-29-2009, 06:11 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
100 ballons and flannel shirts.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 06-29-2009, 07:46 AM
My understanding is that you would use the 55-60 deg-F earth has a huge heat sink. In a normal A/C unit you have to compress the freon, this is where most of the energy cost comes from. If you install a bunch of underground piping that is filled with water or air you can move this air or water for a much lower cost than compressing refrigerant. No propane needed just air or water.
1980 SC
71 Chevelle SS454
Old 06-29-2009, 09:21 AM
and a lot of land
1980 SC
71 Chevelle SS454
Old 06-29-2009, 09:22 AM
