AutoBahned
RWebb's Avatar
Bridge Connectors vs. wood blocking for joists
I tore out all the wood blocking below my main floor (daylight basement ceiling) to install radiant heat pex tubing.
When it comes time to put something back in there (most of the wood blocking was torn up getting it out), should I cut new wood blocking or use steel Bridge Connectors?
Is one better for shear or other earthquake issues than the other?
The steel Bridge Connectors are < $1 each so cost is not a big deal here. They look pretty easy to install. But how strong are they?
Old 07-07-2009, 02:52 PM
LakeCleElum's Avatar
I've used both....The steel goes faster and works just as well.
I was just gonna mention on thing I heard recently about Pex; I heard this from several sources, including one that is an insurance adjuster.
Pex is the breakfast of choice for mice and rats.....They 'naw' thru it, you get leaks and water damage........I recently built a new house, had a choice and glad I chose copper.....Best to make sure critters don't get to your new plumbing.....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 07-07-2009, 05:12 PM
AutoBahned
RWebb's Avatar
thanks!
Old 07-07-2009, 06:55 PM
David's Avatar
Steel's fine. Put them in a straight line. What's the span?
Old 07-07-2009, 07:21 PM
AutoBahned
RWebb's Avatar
they're just regular ol' 16" centers
- 14.25 or 14.5 I guess would be the span - haven't measured yet...
Old 07-07-2009, 09:46 PM
Navin Johnson
TimT's Avatar
No
Span is the length between the ends of the joists...
'69 911 GT-5
'75 914 GT-3
and others
Old 07-07-2009, 09:52 PM
David's Avatar
So you only need one row of connectors.
Old 07-08-2009, 04:07 AM
Think you misunderstood his misunderstanding, that's inches between joists.
It's NOT a 14.24 FOOT span. He's talking about 14.24 INCHES between joists.
Rwebb, what's the span of the joist?
Old 07-08-2009, 09:43 AM
unindicted co-conspirator
looneybin's Avatar
make sure you put a row of bridging in the center of the span.
The area of max. bending moment has the highest likelyhood of twisting.
You may also want to put a row under any walls above that are perpendicular to the joists.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-08-2009, 11:34 AM
AutoBahned
RWebb's Avatar
yes, " = inches; ' = feet (one reason I often use ft. for feet....)
Thx for the wall and center idea - will be putting them there and closer together too.
The span of the 2x10 joists is about 22 ft. where they rest on an interior wall, and another joist picks up at that wall and extends 20 ft. to the rim joist on the other side.
Old 07-08-2009, 02:32 PM
Not as it seems
juanbenae's Avatar
glue the wood with subfloor glue at the floor else she will squeak.
Old 07-08-2009, 03:47 PM
AutoBahned
RWebb's Avatar
what is subfloor glue?
is it just constr. adhesive?
also, you mean glue the edges of subfloor to the top of the joists, right?
Old 07-08-2009, 03:55 PM
Zeke's Avatar
Squeaks are caused by nail that have missed the center of the joist and split the wood. That would be 99% of the time. 22' means you'd have one row at 11' . I'd go with 2 rows unless one under a wall makes the spacing between the next row at 8' or less, both sides.
If you solid block it, how do the pipes get treated? will you be notching or ripping them down for clearance. If ripping, they won't even touch the subfloor. No glue needed.
Yes, he meant construction adhesive. They make a bunch of different kinds now. Wet location, high strength, etc. Just don't buy the cheapest stuff and you'll be fine. I think the cheapest stuff would be for paneling.
Who installs paneling anymore? You could use it for installing 1/4" drywall over existing. Just sayin' so you know why there's a cheaper grade.
Old 07-08-2009, 04:49 PM
AutoBahned
RWebb's Avatar
OK, I am a little confused...
The subfloor (and wood strip floor, stapled #2 Hickory) is ALREADY in place.
I removed the old basement ceiling to gain access to the bays in between the joists.
Now, given that, does it make any sense to squeeze a little glue into the edge formed by the bottom of the subfloor and the top of the joists??
Old 07-08-2009, 04:54 PM
David's Avatar
I'm with Milt on the 2 rows of connectors.
Glue might quiet a squeeky floor some, but it might be a pain if the floor is ever pulled up.
Old 07-09-2009, 12:29 PM
There is nothing wrong with squeaky floors.
They are perfect for busting your little kids sneaking into your bedroom in the middle of the night.
Then of course you always have the benefit of being able to move out of the way at the last second when your local axe murderer comes in to kill you in the wee hours of the morning.
Randy
'87 911 Targa
'17 Macan GTS
Old 07-09-2009, 01:04 PM
Platinum Member
dad911's Avatar
How 'bouncy' is the floor? 22' span on a 2x10 , 16" O.C. is much longer than codes allow. I have never gone over 16' with a 2x10.
Old 07-09-2009, 04:50 PM
David's Avatar
I missed the 2x10 joist. Go with at least 3 rows of connectors.
Old 07-10-2009, 01:44 PM
Navin Johnson
TimT's Avatar
By 2003 International Building Code (IBC), in addition to having to install blocking where joists overlap over a center beam, blocking is also required every 8 feet for 2x10 and taller joists
so to be conservative... 3 sets spaced evenly on the 22' span.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-10-2009, 06:48 PM
AutoBahned
RWebb's Avatar
thx - will do, but...
OK, I am still a little confused...
The subfloor (and wood strip floor, stapled #2 Hickory) is ALREADY in place. I removed the old basement ceiling to gain access to the bays in between the joists.
Old 07-10-2009, 07:01 PM
