Muffler experts - how can I make this quieter?
This is a Danish repro muffler for a 36hp, and it's annoyingly loud. I'm sure there's a way to modify the internals to make it quieter. I was thinking I could insert a roll of perforated metal across the middle, and then pack fiberglass on around it, and maybe pack some fiberglass on the ends, although I haven't torn one of the ends open yet to see what it looks like. Thoughts?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Senior Member
Jeez, its like they forgot ANYTHING inside. Would try what you suggested, and maybe get some metal mesh for the ends and sandwich it with glass in the middle.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Weld in a smaller hot dog muffler.....I dunno, Pack it full of stainless steel wool....
So I made a tube of perforated steel, welded it in, and then packed it with layers of fiberglass and steel wool. I also had to relocated the outlet lower so it would clear the bumper, but that's a different story.
I think that next time I do this, I'll just knock out the mesh pieces in the ends, and push the new mesh tube through those holes. ![]() ![]() ![]() ![]()
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs Last edited by widebody911; 07-12-2009 at 05:38 PM.. |
Senior Member
Well??? How does it sound? Bet a lot quieter.
On a VW, I thought the sound was controlled by the tailpipe. You know that little tweet,tweet sound a VW makes. That sound is because of the chrome tailpipes. If you remove those chrome tailpipes, the car will have a more throaty sound.
I'm not sure if the 36 had a tailpipe. |
Cars & Coffee Killer
What you need to do is completely stop the combustion in the engine, instead of merely muffle it.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
I used steel wool in a muffler once. It lasted 50 miles. Coarse FG works a lot better.
Dunno about the sound yet - I still have to put the rest of the motor back together, but the oil cooler is still in the hot tank.
Ok, I got the muffler installed this weekend. It is now a lot quieter, even though I didn't put any insulation under the end caps. I'm not sure how long the insulation will last, but I am happy with the outcome of the experiment.
