| Registered Join Date: Jul 2003 Location: Valencia Pa.
				Plumbing question??
			I repaired a rental house that had been victim of the midnight plumbers. I had to repair the main water line inside of the block wall, and run up to where the new meter would be.  I have done this on several houses already, and this was the first one that did not have a soft copper line, this one was regular old 3/4" copper pipe. I soldered it up, and the water authority guy came out, and hung the meter. While he did pass my work, he told my partner that solder connections before the meter were not wise, and he would rather see a "mechanical connection". I was not there , so I couldn't ask the questions, but I am assuming he meant a compression fitting, or one of those new style quick connects. Is this correct? I always assumed a good solder joint is about as good as it gets. any advice appreciated
				__________________ No left turn un stoned | ||
|  07-30-2009, 06:26 PM |
| Cogito Ergo Sum |
			I would take that to mean compression fitting.  Hey if you plumb inside much I would suggest getting the good pliers and going to PEX past the meter.
|  07-30-2009, 07:50 PM |
| Registered Join Date: May 2004 Location: Lake Cle Elum - Eastern WA.
PEX is OK if you don't have any rodents around. Rats and mice luv to eat it....Intant leaks.........
				__________________ Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles | ||
|  07-30-2009, 08:13 PM |
| Cogito Ergo Sum |
			Hmm.  We have had any problems with that in OK...  YET....
|  07-30-2009, 08:23 PM |
| Platinum Member Join Date: Jul 2001 Location: Leave the gun. Take the cannoli.
			You can cut it straight and clean up the cut, then push on a sharkbite connector, which will change it to threaded.
|  07-31-2009, 03:47 AM |
