Son of a Son of a Sailor
Looking_for_911's Avatar
Instrument of Satan - repair advice
Hey guys,
I need some help with repairing an Instrument of Satan... aka, a gas operated grass trimmer commonly called a Weed Eater!
I'd rather be shot than use a "weedeater."
I've been shot. With a Govenment Model .45. So I know of which I speak!
Anyway,
The girlfriend bought a new Homelite, one of the curved shaft, lightweight versions. We've used it maybe four or five times. It's worked great so far, ran like a champ, started good.
Except this time.
Last week when in an energetic mood I got out the Instrument of Satan to do some trimming. I primed the carb as I should and gave the rope a pull. It hit on the first pull but died. I then backed off the choke and gave her another pull. It hit and ran but I killed it with backing off the choke too soon. It'll run, so that's not the issue.
Here's the problem....
My mistake was pulling the rope again before letting it rewind all the way, so now I have a rope fully extended that won't rewind.
How does one rewind the rope on an Instrument of Satan?
I appreciate the input but would appreciate more someone coming to the house - and taking care of the grass for me!
Old 08-18-2009, 09:09 AM
Double Trouble
targa911S's Avatar
I thought this was going to be a guitar thread.
Old 08-18-2009, 09:12 AM
The Unsettler
stomachmonkey's Avatar
Sometimes repeated working of the rope will get ti to retract fully.
If not it's take the thing apart but watch out for springs under tension and "other" stuff that will fly out of the thing.
One of the issues with the tension springs is if they unwind they can be a mother f'r to retention properly.
"I want my two dollars"
"Brandon Won"
Old 08-18-2009, 09:31 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
looks like this? http://www.homelite.com/catalog/trimmers/UT21506
BTDT and it's a PITA. I have to disasemble it, to reset the starter. Mine has done it a few times now and needs a new part(#5 in the parts diagram).DO NOT remove #7 which contains the spring under tension.
http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-18-2009, 09:34 AM
Sultan of Sawzall
rouxroux's Avatar
I was thinking bagpipes & accordians....my private hell
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 08-18-2009, 09:44 AM
canna change law physics
red-beard's Avatar
Springs under tension...I still have marks on a finger from the recoil spring from my Colt Defender.
And then there is the scar from the hood springs on my 914. Got me right in the middle finger knuckle.
James
Red-beard for President, 2020
Old 08-18-2009, 09:46 AM
JW Apostate
trekkor's Avatar
They have replacement cutter heads that use thick nylon 'whips' instead of the string now.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 08-18-2009, 10:16 AM
madmmac's Avatar
Lot's of times if you just tap with a hammer a bunch of times where the center of the cord should be winding up it will sloooowly unbind itself and reel itself in.
Good luck.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 08-18-2009, 10:45 AM
Throw that piece of junk in thash. Go to the professional style straight shaft trimmer. They cost more but make the job a TON easier.
Old 08-18-2009, 10:54 AM
red-beard's Avatar
I need to buy a new one. My "old" one, the fuel line inside the tank cracked and broke.
James
Old 08-18-2009, 11:05 AM
is this thing on?
NICKG's Avatar
i have a honda 4 cycle trimmer...cost alot, but definetly worth it. if you don't get one of the hondas, get a redmax or a shindaiawa
"People willing to trade their freedom for temporary security deserve neither and will lose both"
~Benjamin Franklin
Old 08-18-2009, 11:19 AM
red-beard's Avatar
Mine was a Honda
James
Old 08-18-2009, 11:24 AM
is this thing on?
NICKG's Avatar
Originally Posted by red-beard View Post
Mine was a Honda
the parts are REAL cheap...
plano power equipment sells all the parts online ...there are diagrams and all online
~Benjamin Franklin
Old 08-18-2009, 11:29 AM
Believe me, I was not consulted before she made this purchase!
The best trimmer I've ever used is my dad's John Deere.. big honkin' straight shaft that'd sling a baseball two hundred yards and still knock an ol' lady's teeth out!
Old 08-18-2009, 01:17 PM
Good luck.
Oh, how I'd Love to "tap" this SOB with a hammer!!!
Old 08-18-2009, 01:18 PM
I love bagpipes! And I know a Ukrainian accordian player that'd make anyone's "hit it" list. Can't post a pic. She's "happily" married.
Old 08-18-2009, 01:20 PM
I suspect that included in the "other stuff" are mad rattlesnakes and live hand grenades minus pins!!!
Old 08-18-2009, 01:21 PM
Z-man's Avatar
I went with a lawn service this year - NOW that's a ton easier for me! And now, my lawn isn't the worst one on the block!
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 08-18-2009, 02:02 PM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
And I figured this was a thread about Lucas electrics.......
Old 08-18-2009, 04:02 PM
abit off center
cgarr's Avatar
Just put a 24" blade on your 22" mower.
No trimmer needed!
______________________
Craig
G2Performance
Old 08-18-2009, 04:40 PM
