wcc wcc is offline
wcc's Avatar
Anyone willing to help me create a .jpg?
Anyone willing to help me with setting up a .jpg. It will take some of your time as it's all text from scratch. I created a Word document but it only looks good on a 8.5X11 once I blow it up to a 46"wX34"h it's all jagged and doesn't look good. It's taking me a long time to figure this out (learning curve I suppose). Plus I can't get things to line up correctly. If you can help me without spending too much time on it I would appreciate it. PM me your email and I can send you my Word document so you can see what I'm asking and if you're willing to help me out.
Thanks in advance....
Bill
997.2
Old 08-20-2009, 05:08 PM
Gon fix it with me hammer
svandamme's Avatar
download paintshop pro
you can resize all you want with that, change picture formats, what not...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-21-2009, 06:47 AM
Super_Dave_D's Avatar
message sent
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 08-21-2009, 07:07 AM
The Unsettler
stomachmonkey's Avatar
replied
"I want my two dollars"
"Brandon Won"
Old 08-21-2009, 07:17 AM
fxeditor's Avatar
Have you tried making the file a PDF? Then you can scale the document as big as you want and the text will remain crisp.
Good Luck,
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 08-21-2009, 11:44 AM
Any reason why you can't copy the text onto another doc and change the font size to match a larger paper size?
Text should be scalable. If you turn this into a bitmap (jpeg format), the pixels will show when you enlarge. Not so if you use type with the correct pt size.
Open a word doc and configure your printer to Adobe PDF ver. xx, use paper size AO (35x49), then set the type size accordingly. Try 72 pt Times to start. That should get you close. As for printing this PDF doc, you'll have to find a properly sized plotter.
Sherwood
Old 08-21-2009, 12:19 PM
wcc wcc is offline
wcc's Avatar
I haven't tried a .pdf. I just have the reader. I can see if I can get a hold of a full version where I can create one.
I wouldn't mind keeping it in word and making it there but it won't let me resize my page setup to more then 22". What am I doing wrong here?
If I can create it in Word how would I get it to a .PDF? Can't I just print to it?
Bill
997.2
Old 08-21-2009, 01:11 PM
JW Apostate
trekkor's Avatar
'Open Office' has a PDF conversion utility.
I believe it's a free download.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 08-21-2009, 03:30 PM
The Unsettler
Word is the complete wrong tool for this.
"Brandon Won"
Old 08-21-2009, 04:24 PM
I'm working with an earlier version of Word for Mac (2001), so I assume this capability is nothing new. The PDF conversion is completed in the Word print menu. If the configured printer's max. paper size is 8" wide, then Word won't allow you to select a larger paper. I changed the printer type to PDF Ver. XXX, then the paper size as mentioned.
Not sure about how it works for Word for Windoz.
"Word is the complete wrong tool for this. "
If Word can't do it, you're correct. InDesign or Quark may be more flexible in this regard. BTW, I opened InDesign (CS3) and was able to configure any paper size.
Sherwood
Old 08-21-2009, 09:29 PM
wcc wcc is offline
wcc's Avatar
Thanks for all the help and advice from everyone. I downloaded that 'Open Office' and it seemed to do the trick. I created it in there with my dimensions and exported it out to a .pdf. I have to correct spelling and grammar, but it looks like I'm off and running. Thanks again!
Bill
997.2
Old 08-22-2009, 09:04 AM
