Computer guys...PC motherboard question
Since I am the family computer geek, it has fallen to me to try and resurrect my father in law's PC. No big deal, he wanted to put it together to have for the grandkids to play on. He has another which he uses for his work.
Anyhow, the thing has a bad IDE connector. There are only two on the board. So, you can either plug in the hard drive or the CD ROM, but not both. I pulled the motherboard out and was planning on just buying a cheap replacement off the net.
Here's the kicker. The damn thing is a Dell. So of course it is a funky mobo with non-standard connections. The computer in question is a Dell Dimension 4550. It has a P4 2.5 ghz processor on it. I have read that Dell also uses non-standard power connections and such so you can't use the power supply unless you buy another Dell mobo. Of course their replacement sells for $120, which is ridiculous.
Any ideas? I guess I could just buy a new case and mobo and start from scratch...problem is I'd have to buy a heat sink too.
Rick
1984 911 coupe
Old 09-20-2009, 09:14 PM
slodave's Avatar
I put an Intel MB in a Dell case. I think I lost the front USB and sound connection. You can get everything else to work.
Old 09-20-2009, 09:19 PM
Slackerous Maximus
HardDrive's Avatar
Can you post a photo of the power supply connectors?
I don't know your specific machine, but yes, Dell mobos tend to be non standard, along with their cases. Processor, memory, and HD are all usable, but chances are you will need a new case, mobo, and possibly a power supply. Given how cheap one can get a new PC these days, not sure its worth your time.
2014 Cayman S, PDK
Old 09-20-2009, 09:30 PM
slodave's Avatar
Power supply connections are standard.
Old 09-20-2009, 09:36 PM
bonkers's Avatar
Does not compute: a single IDE channel is capable of supporting two drives and you can mix Hard Drive and CD-ROM on one channel. You just need an IDE cable with two connectors - few $ - and make sure the jumper on the back of the CD-ROM is set to slave. The Hard Drive should already be set to Master but check that also.
Might notice a bit of a performance hit if it's trying to access both drives but it will work.
Carrera 3.2 - "Faster, Stronger, Better"
Old 09-20-2009, 09:44 PM
Why not buy a pci IDE card and run the hard drive off it? Do they still sell those ? I'm on my BB, otherwise I would look it up.
Old 09-20-2009, 09:55 PM
slodave's Avatar
Bonkers is right in trying to connect both to one channel.
Old 09-20-2009, 09:56 PM
rnln's Avatar
In old/IDE cable, there usually 2 connectors, one can be for HD and one can be for the CD/DVD. If this cable doesn't have both, maybe a visit to a computer store for a cable?
Fat butt 911, 1987
Old 09-20-2009, 11:09 PM
Platinum Member
dad911's Avatar
Yes, 2 drives on an IDE port, 1 master and 1 slave. Or lose the internal CD, and plug in an external DVD through the USB.
Old 09-21-2009, 04:31 AM
Happiest when Tinkering
gsmith660's Avatar
+1 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150410%201193212548&name=IDE
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 09-21-2009, 06:39 PM
19 years and 17k posts...
azasadny's Avatar
Promaise sells cards to add hard drives, check on eBay. Promise Ultra100TX2, I believe...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-22-2009, 07:04 PM
slodave's Avatar
There's no reason to spend money until he tries to hook the HD and optical drive to the second channel.
Old 09-22-2009, 08:01 PM
