Stuck rings -What to do?
I am working on a 1967 Wisconsin 4 cylinder engine. I think one cylinder's rings are stuck. 0 compression, put a little oil in the cylinder and it jumped up to 30 PSI immediately.
What should I use to try and free them up? ATF? Marel Mystery Oil? Ideas...Let's hear them Thanks... |
Take it apart and fix it if you want it to run right. Phosphoric acid will dissolve the rust, then oil might work.
RETIRED
Marvel Mystery oil....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bill is Dead.
Are you going to pour it in and let it sit?
Some old timers like wintergreen oil / methyl salicylate. Some people say a 50/50 mix of ATF and acetone.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
Formerly reformed
I have been using Marvel with good results. Plus, it's inexpensive if it does or does not work. Have to rotate engine and such . . .
1968 911P (Paperweight) |
Parrothead member
Soak with ATF . I've loosened up frozen boat engines many times.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
atf or seafoam. Soak over night a couple of times. I've done this to several Wisc. with great success.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Architecture & Porsche's
I successfully un-rusted a once-hydrolocked inboard/outboard using PB Blaster & about 3 applications over 3 weeks. Oh, & a strong battery
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Formerly reformed
I don't care what type of success you guys have had . . . Marvel smells better. So there's something to be said for that.
Try some Kroil by Kano Laboratories.
Unless I'm tuning, my nose is nowhere near my tail pipe.
Thanks for the replies. I soaked it in ATF last night, I'll check it Sunday and see if it's any better.
Someone said to rebuild it. I probably will and I would just tear it down instead of trying to free the rings but it is going to be a MAJOR PITA to get it out of the vehicle it's in |
