Stuck rings -What to do?
I am working on a 1967 Wisconsin 4 cylinder engine. I think one cylinder's rings are stuck. 0 compression, put a little oil in the cylinder and it jumped up to 30 PSI immediately.
What should I use to try and free them up? ATF? Marel Mystery Oil?
Ideas...Let's hear them
Thanks...
Old 06-07-2012, 12:40 PM
wdfifteen's Avatar
Take it apart and fix it if you want it to run right. Phosphoric acid will dissolve the rust, then oil might work.
Old 06-07-2012, 12:49 PM
RETIRED
Joe Bob's Avatar
Marvel Mystery oil....
2012 ML350 3.0 Turbo Diesel
Old 06-07-2012, 12:51 PM
Bill is Dead.
cashflyer's Avatar
Are you going to pour it in and let it sit?
Some old timers like wintergreen oil / methyl salicylate.
Some people say a 50/50 mix of ATF and acetone.
Old 06-07-2012, 12:52 PM
Formerly reformed
I have been using Marvel with good results. Plus, it's inexpensive if it does or does not work. Have to rotate engine and such . . .
1968 911P (Paperweight)
Old 06-07-2012, 01:05 PM
Parrothead member
VINMAN's Avatar
Soak with ATF . I've loosened up frozen boat engines many times.
Vinny
Old 06-07-2012, 01:19 PM
DUK DUK is offline
DUK's Avatar
atf or seafoam. Soak over night a couple of times. I've done this to several Wisc. with great success.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-07-2012, 02:12 PM
Zeke's Avatar
Which can't be much different than ATF and kerosene.
I tried the acetone/ATF mixture recently as a bolt loosener in lieu of PB Blaster. I think I'll stay with PB. The acetone evaporates quickly and you have ATF.
Old 06-07-2012, 02:33 PM
Architecture & Porsche's
I successfully un-rusted a once-hydrolocked inboard/outboard using PB Blaster & about 3 applications over 3 weeks. Oh, & a strong battery
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-07-2012, 02:44 PM
Formerly reformed
I don't care what type of success you guys have had . . . Marvel smells better. So there's something to be said for that.
Old 06-07-2012, 05:10 PM
Zeke's Avatar
Right. Put a little vanilla extract into anything you make that is a secret. Throws 'em off every time.
Old 06-07-2012, 05:23 PM
Try some Kroil by Kano Laboratories.
Old 06-07-2012, 08:16 PM
Unless I'm tuning, my nose is nowhere near my tail pipe.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-08-2012, 05:06 AM
Thanks for the replies. I soaked it in ATF last night, I'll check it Sunday and see if it's any better.
Someone said to rebuild it. I probably will and I would just tear it down instead of trying to free the rings but it is going to be a MAJOR PITA to get it out of the vehicle it's in
Old 06-08-2012, 07:11 AM
