Auto detailing...TREE SAP! ARGH!
I just bought a BMW 325i in Titanium Silver with 22k miles on the odo. I am assuming this car was bought at auction because the clock inside was 2 hours earlier than central time. Anyhow, the horizontal surfaces (hood, roof and trunk deck) all have very small black dots all over the paint. I am assuming this is very small areas of tree sap or some other contaminant. I would very much like to get this stuff off my paint.
I tried a clay bar, the paint was rough as hell and the bar took off maybe 10% of the dots but not nearly all. I then pulled out some rubbing compound I had and tried that. It works and removes the dots but man, it takes forever! I spent 10 minutes and maybe had a 6 inch square clean. Is there anything else I can try to get this stuff off a little easier? I guess I could just sit there and use rubbing compound on each panel over time but I am hoping there is an easier way. I tried to take pics but the camera won't pick up the dots. Yes, I know I am being anal.
Rick 1984 911 coupe |
Checked out
You don't want to try to remove that mechanically (like by polishing, or *gasp* compounding!). You'll do more damage than good to the paint.
You need to remove it chemically, there are all sorts of tree sap removal products on the market. Just one example (there are many others): Tar Remover | Tree Sap Remover & Asphalt Remover I'd call a good automotive detail supplier and ask what they have. Your local auto supply stores probably have stuff, too. |
Any bug and tar remover should work. Let it sit on the spots for a few minutes to soften them up. I would then follow up the treatment with the clay bar, polish, and then wax.
Also, if the little lady has any, Avon Skin-So-Soft does wonders on that sort of thing. We used to use it to remove the rubber from our burnouts that accumulated behind the tires.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
naturally aspirated
I use a spray of alcohol, let it soak in. Then spray with WD-40, gently wipe off with microfiber.
Rule of thumb, use organic solvent for an organic stain (ie alcohol). |
Banned
Prep sol.
Rub on, rub off. Get it at any detailing supply shop. |
19 years and 17k posts...
I've used Goof Off to remove pine tree sap and it worked well. It also removes all wax, so I rewaxed it as soon as the sap was removed.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
**Warning** If you do this right, it works flawlessly. If you do it wrong you are going to scratch the snot out of your paint. So if you've ever been referred to as a hairless monkey, as having all thumbs, or two left feet, please stop reading...
Take a fresh razor blade. Scrape it vigorously on the windshield. You are slightly rolling the edge of the blade. It's now directional meaning that the rolled edge should be pointing up away from the windshield. Keep it in the same direction while you work on the paint. Work the blade nearly horizontal to the panel and scrape off the sap. If you do this with care you won't leave a mark on the paint at all and can usually do even a severely "sapped" car in an hour. Follow up with a good polish and at least two coats of wax. I put myself through college running a detail business and probably did this to at least 40 or 50 cars. Done right, it works perfectly. Don't even think about doing it wrong. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Wow, that sounds a bit dangerous to me...I would not be comfortable taking a razor blade to my "new" car.
I did go out and try the clay bar again, I was pleased to see that it does take the stuff off, you just have to rub a little harder with it and reknead the clay from time to time. The paint just has so much crap on it that it loads the clay bar pretty quickly. I may end up claying the whole car twice just to get the paint clean. It amazes me how poorly people treat leased vehicles...oh well, I guess my new baby just needs some extra lovin...
I would go the chemical route first. Paint thinner or other products to dissolve the sap. As far as Goof-off, I would avoid this stuff. It is really aggressive and I use it only for dried latex paint on areas that are not painted, like a dried spot on the carpet or floor. I have seen this stuff melt and dissolve paint and plastics pretty easily.
Here, I pulled this directly off the goof-off website:
"CAUTION: Always test on inconspicuous area first. Damages many plastics, worn vinyl floors, some automotive paints, and some carpets. " |
Banned
Prep Sol will remove the sap in seconds.
Platinum Member
May not be sap. Do you park near mulch? If so, it is probably "artillery" fungus, I have seen whole houses covered with it.
Strange Brown Dots http://www.nnjr-pca.com/forum/viewtopic.php?f=5&t=3242&p=38998&hilit=mulch#p38998 |
Update!
I have a firm diagnosis on the black spots. It is not tree sap after all, it is "rail dust" or "industrial fallout". I have spent the entire day washing, claying, washing again, polishing and then waxing the car. Damn my arm hurts! Where is Mr. Miyagi when you need him. Anyhow, I figure I got about 95% of the specks off with the clay bar, some of em took more rubbing than others. Those clay bars are truly amazing. When I have used them before it was on a fairly new finish so I wasn't that impressed. Today was removing 3 years of built up crap on the paint. Some of those areas felt like medium grit sandpaper when the clay first went over them! Anyhow, I am now pretty happy with the finish on my car. Next wash I will probably clay it again and get the last few specks off. Now the only issue is that there is a tick in the engine at idle. Just started today so I'm hoping it will go away. If not, it's under warranty!
Rick 1984 911 coupe Last edited by Nathans_Dad; 10-17-2009 at 05:34 PM.. |
Gratuitous pics:
Beautiful car. I am impartial to BMW's. The clay is great for removing stubborn film but you may want to use some polishing compound to remove any surface scratches before you use a wax. By that time, your triceps should be able to handle it.
Banned
I dunno man, you are saying prep sol will remove rail dust embedded in the clearcoat?
Banned
Anything on the surface miagi-son. Wipe on, wipe off.
Oh well, I thought you were saying it worked for tree sap. I figured this rail dust stuff was different.
I got a good tricep workout though!
