Bill Douglas's Avatar
Excel question.
Hi Guys, a really strange thing has happened with the formating, I guess, in Excel. When I type in a number such as 45 it appears as .45. If I want it to appear and behave normally as the number 45 I have to type in 45. (or 45.00). I can live with this but I'm afraid I going to make a big mistake with something. Any ideas?
Old 10-27-2009, 07:14 PM
Licensed User
Shuie's Avatar
right click, format cells. And, yes, you will probably make big mistakes in Excel no matter how you format. It happens to the best of us. Excel does evil things in your spreadsheets that you do not want. I wish you luck.
Old 10-27-2009, 07:18 PM
The Unsettler
stomachmonkey's Avatar
You want it formatted as a Number with no decimal places. Formatted as General will work also but may do strange things when used in equations.
"I want my two dollars"
"Brandon Won"
Old 10-27-2009, 07:24 PM
Thanks, but if I go Format, Cells, Number, and set it to 0 decimal places the number 45 displays as 0.
Format, Cells, General displays it as .45
Old 10-27-2009, 07:41 PM
The Unsettler
Not sure what version of excell you are using.
Go to Preferences, look for Edit, Uncheck or set to 0, "Display this number of decimal places" option.
"Brandon Won"
Old 10-27-2009, 08:05 PM
Registered Abuser
MT930's Avatar
up to Format
Cells
Number
Box says decimal places
select 2
should be OK then
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 10-27-2009, 08:07 PM
Nope
When I enter in the number 45 it is 0.45 on the spreadsheet.
Old 10-27-2009, 08:19 PM
The Unsettler
Nope
Application preferences.
It's an application wide setting, not entry based like the Format option.
There is a general setting there.
I was just able to replicate your problem.
It will not change a current entry, only entries that occur after the preference is changed.
In my version of excell it's "Display this number of decimal places".
"Brandon Won"
Old 10-27-2009, 08:27 PM
Mine is an earlier version of Excel and doesn't have an option called application preferences. the strange thing is it used to work well for the fairly simple stuff I do on it.
I just opened an old spreadsheet and it works fine, it's just anything new I do
Update: even on the old, OK, Spreadsheet if I enter a new number if does the 45 to 0.45 thing but the previously entered data displays OK.
Old 10-27-2009, 08:39 PM
Go to Tools - Options - General tab and uncheck the Fixed Decimal places box.
Kevin
'87 Targa
Old 10-27-2009, 09:18 PM
Kevin. You are my friend. Thanks, this was driving me balmy LOL.
Old 10-27-2009, 09:28 PM
