Evil Genius
Why Men shouldn't write advice columns...
Life is a big ocean to swim in. Wag more, bark less.
Senior Member
She might also check for water in the fuel tank...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Cars & Coffee Killer
This is obvious. She should check the gauges behind the photo of her dog.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Targa, Panamera Turbo
ethanol is to blame...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Model Citizen
. . . she said it stalled, then it broke down? Does this mean she was able to get it running after it stalled? I'm thinking it might just be out of gas, because the implication is, as I read it, the car is still getting spark. . .
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Occam's Razor
My advice - join in.
Craig '82 930, '16 Ram, '17 F150 |
Like a woman would be able to provide better automotive advice? Sheesh.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
Sorry. Not believable, it has to be made up.
No woman would walk a mile for help. She might phone her husband who could be 100 miles away, and would be expected to repair the car with an hour. But she would never walk. |
When you have someone who knows nothing about cars tell you their car stopped running, the first thing you should do is ask them if they can smell anthing burning or smell fuel. If no, then have them turn on their headlamps. If the lamps are extremely dim, the charging system is likely the issue (battery/cables and/or alt). If the lights are bright, crank the engine. Engine cranks normally indicates good battery charge, acceptable cable condition. Ask if they smell gas now (if yes - good chance fuel system is working but ignition becomes a likely suspect - they can't fix it either way, you're only satisfying your curiosity). This is really all the further most inexperienced drivers can be safely expected to help you diagnose a repair over the phone. After this, have them turn on their four ways and start walking because most real beginners can't tell a vacuum line from an air conditioning line or an intake manifold from a brake reservoir. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
"can't tell .... an intake manifold from a brake reservoir"
I have this line in my head "can't tell a camshaft from a quick-change (rear end). Jim
down to jap bikes that run and a dead Norton |
abides.
The columnist didn't even ask for pics of the neighbors daughter!
Graham 1984 Carrera Targa |
