I'm with Bill
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I can do a Honda 4 banger timing belt on a 93 in less than 3 hours. Ive done many of them in my time. I was in a dealership service dept for over 11 years and I can tell you that most people dont take into consideration that techs dont just walk up to a car already in the bay, all the correct tools laying out, parts already at the car, and spec sheets and info laying on the car . I have participated in flat rate time calculation test with GM and Mazda as a tech and as a tester. Everything is all layed out, tools, parts, books and what not . Then the techs perform the job start to finish 10 times. The AVERAGE time is then figured and that is the time that goes to the flat rate for taht operation. The reason a tech can beat the times comes with his experience . Most techs spend a lot of time losing ground to the flat rate calculations, especially on water leaks, squeaks and rattles and pita things before he gains the experience to actuall make or beat time. Remember, if you tech takes 3 times as long you still only pay for the flat rate time . So it is give and take sometimes. Flat rate time should be around 1.3-1.7 hrs for a job like that Plus parts, taxes and shop supplies. So with average rate of $95.00 per hour and using OEM gasket , $200.00 is probably about right. Last edited by vwbobd; 01-05-2010 at 10:47 AM.. |
Actually most of my time was as a Fixed Operations Director at a very large volume, multi line new car dealer. We had 25-30 techs in service , 12 in the body shop, 9 in parts, and averaged sales of over 3200 units per year. We used the Mitchell flat rate book in service . I had body shop guys who could beat the body shop book by a mile. One of them averaged over 100 hours a week in flat rate time . He is the best body man in the business. Oh, and thank you, thank you very much.
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
[QUOTE=javadog;5107726][QUOTE=red-beard;5107702]Javadog, how long would it take your technicians to do a timing belt?
[QUOTE=vwbobd;5108194][QUOTE=javadog;5107726]
Car lasted me 230K miles (Fall 93 to Spring 01, so 7.5 years), so I can't complain too much. The radiator needed to be replaced, because the road salt corroded the hell out of the aluminum fins. I replaced it with an aftermarket copper one and it ran great. Drove the snot outta that car. I only replaced it because I wanted 4WD for skiiing.
Banned
No wonder it takes you so long. |
Banned
If you add in all the other stuff, pulling it in, putting it on a lift, test drive, blah, blah, blah....45 minutes is more reasonable for the entire job. Considering that the only part in play is a valve cover gasket, i would consider $200 to be highway robbery. Last edited by m21sniper; 01-05-2010 at 01:49 PM.. |
Neil '73 911S targa |
Writer/Teacher
Thanks, guys - as usual, this was helpful.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
