Writer/Teacher
Is my friend getting hosed?
As part of a "routine maintenance" on his 110K mile Honda Accord (a service that would include belts, plugs, "rotating tires," etc.), my friend's mechanics said they need to "check his valves" as part of "preventative maintenance." They plan on charging him $210 for this. I'm assuming that they mean intake/exhaust valves. This seems odd to me; the only time I've ever gone anywhere near valves in a car is when I've broken a timing belt or blown a head gasket.
Are they trying to rip him off?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Detached Member
Check the owner's manual. Not usually since most valve trains are hydraulic and you can't adjust.
Hugh |
It depends on the Honda. The older ones required a valve adjustment every 15k miles.
JR |
Writer/Teacher
His is a 2005 or 06, I believe.
As a rule of thumb, I don't pay jack for "checking" anything. If they're going to adjust the vales that's a different story.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Navin Johnson
Valve seat wear.. Valve guide wear...
Wear in the valve train... the car has 110K on the clock...Some of our beloved Porsches have trashed valve guides a lot sooner than 110K not sure how Hondas hold in this regard.. So they are going to pull the head... check the valves for $210?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
canna change law physics
Hydraulic Valve lifters? These are overhead cams. It is about a 10-15 minute job, involving pulling the valve cover and rotating the engine and checking/adjusting the clearence. 15K miles? Sounds about right. I haven't owned it since 2001.
$200+ for the check? Well, add in a valve cover gasket and then add in the time minimum (maybe 30 minutes) and you'll certainly get $200+.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Come to think of it, I think it was every 30-45K miles.
7.5K is oil change 15K oil Filter Yep, 30 or 45 for Valve clearence 90 for timing belt (I did mine twice!)
Which model? Which engine? In 2005 they were still using engines that required periodic valve adjustments.
The easiest thing to do would be for him to look in his owner's manual to see if there is a valve adjustment interval specified for the particular engine in his car. JR |
I'm with Bill
Honda still has adjustable valves on some models. They also require the upper plenum to be removed to get the valve covers off.
Like JR stated, check the owners manual for the adjustment interval.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
3.4 Bigger is better
My 2003 Accord V6 needs to have the valves checked/adjusted at 105,000 along with a new timing belt and I will replace the water pump and spark plugs all at the same time. Everything except the water pump is called for in the 105,000 mile service. WP just makes sense since you have to take off the timing belt to replace the water pump.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Unfortunately this is exactly the kind of job that gets billed and never done at some shops. Assuming they do the work that's not a bad deal, assuming new gasket. If it's a V6 it's not a bad deal at all.
Banned
Adjusting valves is very fast and easy once the cam/valve covers are off. I've done several 4 cylinder/2v valve adjustments in 10 minutes. It's really easy. Never done this particular model, but unless they've re-invented the wheel, it shouldn't be any harder than doing the valves on a Suzuki Samurai, or whatever else.
You guys are good. Even if you rig a remote start switch, it takes a few minutes to line of engine correctly to check each cylinder. I guess I'm slow, I do them one at a time, rather than figure out that when 1 is TDC, you can adjust more than just cyl 1.
When I was a Honda dealer, it took a lot longer than 15 minutes for my technicians to do a valve adjustment. And, they did them all day, every day, so they were quite good at it. It's amazing how the advent of the internet has increased the productivity of some people.
My suggestion for the guy that gave rise to this thread would be to actually talk to the shop that quoted the work and find out what they are actually doing. When we did a valve adjustment on an engine, it was always in conjunction with other work. He ought to also be able to shop around a little. Any decent-sized city will have more than one Honda dealer, as well as a bunch of independent Honda shops. JR |
![]() As far as the guy who said he wouldn't pay for any kind of "check", exactly how much time do you think is involved in checking over a vehicle? Do you just wait until things break before getting them repaired? How would you like your family to be traveling in a car and have something go wrong in a bad area or at night just because you think you were smarter than the vehicle engineers who don't have enough sense to determine at what point an issue may become ...well, an issue? |
Besides, go back and read what I said. I was justifying the cost and thought it was reasonable for a valve check. Javadog, how long would it take your technicians to do a timing belt? I know your book says 8 hours, and that is in a shop with all of the right equipment. I had it down to about 10 hours on my driveway without a lift, and that included time for lunch. I discussed this with a Honda Dealer shop manager (They were working on my A/C), and told him about it taking 10 hours. He laughed and said that the book says 8 hours, but his techs could do it in 3.5.
[QUOTE=red-beard;5107702]Javadog, how long would it take your technicians to do a timing belt?[QUOTE]
You know, its been too long for me to remember. The guys could always beat the flat rate from a Chilton, or similar flat rate manual. Not always by a lot, it depended on the job. The Honda flat rate was what they paid for warranty work and it was considerably less than the other manuals. They had a very hard time equalling that, especially for jobs they only did a few times. After 8 or 10 trys, they could get down to Honda's times. Honda was cheap. I wouldn't work for the flate rate they paid. One other thing to think about, there's at least 15 minutes used up for a technician to be assigned a job, go get the car, get it on a lift, get the parts needed, test drive the car, return it to the lot, complete the paperwork, etc. It's not an easy living. JR |
I never said otherwise. And your boys weren't getting paid the shop rate! Nope, I wouldn't run/operate/own a service shop. Far too many crazy people out there.
