exitwound's Avatar
A Three-Cylinder Porsche? More on the 2012 Boxster
Hopefully this thread, unlike the other, will stay on target.
Porsche Considering Three-Cylinder Engine For 2012 Boxster - MotorAuthority
Porsche is in the midst of developing its next-generation Boxster sports car, which has been seen undergoing testing in prototype form on a number of occasions in recent months. The new car is expected to go on sale late next year as a 2012 model and according to a new report Porsche may be planning a special fuel-efficient model.
A rumor alleging that Porsche insiders are talking about a lightweight, turbocharged four-cylinder platform for the 2012 Boxster recently began making the rounds, however, the car’s model line director, Hans-Jurgen Wohler, has revealed to Autocar that a turbocharged three-cylinder powerplant may even be possible.
Installing a downsized engine would be one way for Porsche to reduce its fleet emissions in line with tough new government standards coming into play in the U.S. and Europe over the next couple of years.
“A Boxster with a four-cylinder engine, or maybe even a three-cylinder turbo, could produce between 180 and 200 horsepower,” said Wohler. “Given the Boxster’s history--that it started with a 200 horsepower, 2.5-litre engine--I think this is possibly something that customers could accept.
The thought coincides with possible rumors of a revived 914 that could be co-branded by both VW and Porsche, targeted at different market sectors, which means the new Boxster could certainly be fitted with a compact turbocharged mill. If that’s the case, we're sure Porsche will still offer a six-cylinder option for upper range models.
[Autocar]
-Patrick
Black 1986 944
Old 01-04-2010, 05:49 PM
Bandwidth AbUser
Jim Richards's Avatar
I doubt customers would accept 180-200 HP without a significant weight reduction.
Jim R.
Old 01-04-2010, 06:45 PM
meister member
speedracing944's Avatar
A Lotus Elise or Exige can get away with this but not a Boxster. 2000lbs vs 2900-3000 lbs for the Trister, um I mean the 3 cylinder Boxster.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-04-2010, 07:10 PM
Did you get the memo?
onewhippedpuppy's Avatar
100 less HP in the same car? Not gonna cut it.
‘07 Mazda RX8-8
Old 01-04-2010, 07:27 PM
exitwound's Avatar
Even if the price was perhaps $10000 cheaper?
-Patrick
Black 1986 944
Old 01-04-2010, 07:32 PM
Banned
m21sniper's Avatar
3 cylinder engines are very much NOT smooth. A 3 cyl has no place whatsoever in a performance car.
Old 01-04-2010, 07:37 PM
Bandwidth AbUser
Patrick, they might as well badge it a Vdub. No, it won't cut it as a Porsche without a corresponding reduction in weight to make it a performance car. Snipe's comment is a good one. I wonder how you make a smooth 3-banger.
Jim R.
Old 01-05-2010, 05:19 AM
300hp 1800lbs is the goal
pksystems's Avatar
They might aswell buy aluminum frames from Lotus (everyone else is) and put a turbo 4 in
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-05-2010, 05:20 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
No ma'am. I don't like it. I don't like it at all.
Flat-6, fine. Even a flat-4 would be acceptable. Or an inline 4 (which means it's no longer a Boxster, but a Linester or something... 3-cyls belong in outboard motors or in dirtbikes. Not sports cars.
As has been said, they're inherently unstable. My parents have a boat with a 3-cyl outboard. It's got a lot of vibration issues.
Black Cars Matter
Old 01-05-2010, 05:44 AM
Two words.
Balance shaft.
I'd much rather see a flat four, than a three. At least there is a precedent for that.
JR
Old 01-05-2010, 05:58 AM
Bandwidth AbUser
Thanks JR. I imagine that a balance shaft would rob some of the power from an engine that employed one.
Jim R.
Old 01-05-2010, 05:59 AM
VincentVega's Avatar
Big heavy balance shafts would help but big and heavy seem counter productive in this case.
I like the idea of a stripped out, 4 cyl turbo boxster coupe, er Cayman. Cloth, manual seats.... So so much on a 3 cyl.
Old 01-05-2010, 06:04 AM
exitwound's Avatar
Oh I'm not advocating that they put in a 3cylinder. Just asking for thoughts about it.
I don't necessarily consider the Boxster a "performance" car though.
-Patrick
Black 1986 944
Old 01-05-2010, 06:31 AM
The smoother you want the engine to run, the heavier some of the masses need to be. I'm thinking of mainly the crank weights and the mass of the flywheel. These would help with smoothness at idle and low engine speeds. The higher they spin the engine, the greater the need for the balance shaft. They could go with a lower rev limit, which isn't always a bad thing when turbocharging an engine.
The other thing to consider is that 3 cylinder engines are usually quite small in displacement. VW has done a few over the years and they were generally between 1 and 1.5 liters. If you make a large displacement 3, the individual cylinder displacement quickly becomes large. This isn't conducive to a smooth engine, as you might remember from some of Porsches' other entry level products.
I also question whether the public will accept a lower-performing Porsche, in an age where even the pedestrian Hondas are getting pretty quick. I suppose you can't blame Porsche, as it's the f'ing politicians that are making the future fuel economy rules.
Some of you gun enthusiasts need to take care of this problem.
JR
Old 01-05-2010, 06:34 AM
RE: 3-cyl; I heard they were working on building half a Porsche, just didn't know which half.
Seriously, I've been reading that the spy video/photos are of a Speedster/Spyder model which will weigh 200 lbs less because of the removal of the elec/mech operating roof. Plus it will get an additional 10 hp over the "S" model.
I think that an all electric Porsche will hit the show rooms long before a 3-cyl or Diesel model.
Saying that, a turbo 4 cyl inline costing 10k less sounds like a good marketing move.
Half the buyers are women, right? I'm sure at least half the buyers will not care what's under the hood as long as it says Porsche.
Old 01-05-2010, 08:28 AM
Actually, that one has already been announced and I'm sure you could go down to your local dealer and order one:
The one in this thread is probably at least a couple years away.
JR
Old 01-05-2010, 09:37 AM
JR
I know that one, not what I meant.
I think I read somewhere that this one (part Speedster/ part Spyder) will have the standard windshield height, but a similar top to the Speedster (and turbo-4).
All conjecture at this point, but it maybe another way to bring down the final cost. Perhaps the top down and masking bra where the humps would be cause this theory to pop up.
Porsche Boxster Turbo: Spy photos and video! - The German Car Blog
Old 01-05-2010, 09:55 AM
Banned
m21sniper's Avatar
It certainly would. Balance shafts also slow down revs (ie it takes longer to rev the engine up), and they reduce throttle response, as well. The increased weight of the reciprocating mass definitely hurts responsiveness.
This is just a flat out stupid idea.
Old 01-05-2010, 01:51 PM
Why would adding a balance shaft increase the weight of the reciprocating (pistons, rods, valves) parts?
I can see the 'flywheel effect' of the weight of the balance shaft rotating mass hurting responsiveness, though.
Old 01-05-2010, 02:12 PM
Banned
m21sniper's Avatar
Originally Posted by tcar View Post
Why would adding a balance shaft increase the weight of the reciprocating mass?
I can see the flywheel effect of the weight of the balance shaft rotating mass hurting responsiveness.
The balance shaft has to be spun up and decelerated too. That takes energy and time.
Old 01-05-2010, 02:14 PM
