stevepaa's Avatar
choosing boot disk in XP?
I made a clone of internal PC disk. How can I boot from the external clone?
Old 02-10-2010, 03:32 PM
slodave's Avatar
1) What did you use to make the clone?
2) if it is a true mirror of the 1st drive, then you have to modify the boot.ini file by hand to get the other drive to come up n the initial boot menu...
How to edit the Boot.ini file in Windows XP
Old 02-10-2010, 03:41 PM
stevepaa's Avatar
acronis
thanks. i'll try that.
Old 02-10-2010, 03:46 PM
slodave's Avatar
BTW, I've never tried to add a bootable 'external drive'... I take it this would be through USB? If so, You can go into the MB BIOS and change a boot setting to boot USB drive first. In this setup, just remember to unplug or plug the external drive in before turning the computer on...
Old 02-10-2010, 03:57 PM
Not that I can answer your boot disk question, but I also have a similar question...
Having just reinstalled XP, I want to make an image of the new install.. so that when I have to reinstall again, I don't have to go through the whoel process over...just copy the image.
Any tips on this?
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 02-10-2010, 04:12 PM
slodave's Avatar
Check your PM, Wolfe..
Old 02-10-2010, 04:24 PM
stevepaa's Avatar
yes, a USB drive. I have always used macs. This is a new experience for me.
I have not used CLI since VAX days
How does one go into the MB BIOS and change it? thanks
Old 02-11-2010, 08:35 AM
Evil Genius
Rusty Heap's Avatar
I just bought Norton Ghost, which is supposed to do a full hard-drive copy for full recovery / reinstall if a system crashes. Haven't even openned the box yet though.
Stevepaa, for BIOS access, every PC is different, but right at the start of power-up, you are prompted to go into a set-up menu for a brief second, or, while first powering up, you have to hold down a CTRL S, or CTRL F8 key type of arrangement command to get into the low level BIOS.
tread carefully in there though!
Life is a big ocean to swim in.
Wag more, bark less.
Old 02-11-2010, 10:50 AM
stevepaa's Avatar
found it, and tried it. But it got a disk read error and would not boot from the usb drive, so I reset back to what it was and everything works fine as before. I wonder what is wrong with my cloned disk?
Old 02-11-2010, 10:59 AM
slodave's Avatar
I had not tried this before, but in reading now, it looks like it is not so easy to do with Windows...
Ngine.de - How to install and run a FULL Windows XP from a USB drive
From the little reading I just did, it looks like it may not be able to be done with an existing installation of XP.
Dave
Old 02-11-2010, 03:37 PM
