winter-hater club member
i burned rice in my stainless saucepan the other night
is it ruined? the rice pretty much carbonized onto the inside of the pan. any suggestions on getting this thing clean?
TIA!
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Scrape off what you can. Then use a wire brush attachment on a portable drill - or even a drill press and grind away at what's left. BTDT.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
abit off center
you got a bead blaster?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
My wife has burned plenty of stuff in our stainless pots. I use elbow grease and a scotchbrite pad.
Used Up User
When all else fails, throw in a can of tomatoes & simmer for several hours. The acid in tomatoes is a great pot cleaner. Squirt in some lemon juice as well for good measure.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Toluene....
stainless wire brush? i've soaked it in white vinegar for two days, no improvement.
that is exactly where i was going, but i used some yellow scotchbrite and it seemed to polish the carbon. seriously.
Boil water in it. Low simmer. And don't let it boil dry.
I'd try this before more aggressive mechanical means.
poof! gone |
i tried this. after burning the rice, i scraped it out, scrubbed it vigorously, and cooked more rice. (yeah, i needed rice for the meal and i had the time).
man, that is awful. burnt rice is difficult to clean. good luck.
if you eat alot of rice, may i suggest a cheap rice cooker? i used to burn rice all the time!! the cooker was mandatory for me.
poof! gone |
Slackerous Maximus
Bar Keepers friend for stainless. Does the trick.
Cookware Cleaner | Cookware Cleaning | Bar Keepers Friend
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
I'd soak it for days, then go at it w/ a scraper (round off the corners) to get the worst of the rice off, then soak more, then scrape again. Then wire wheel in a drill, finish with a buffing wheel in drill plus polishing/rubbing compound. It will be lots of work, no shortcut that I know of.
If you want to gamble, maybe put pan in oven and run the self-cleaning cycle? |
Soak in in water for a day. Scrape the bottom and vertical part of the sides clean using a single-edge razor blase at a shallow angle. Finish with coarse copper cleaning pad. Takes maybe 5 minutes.
Don't use anything harsher than that. JR |
Steam cleaner!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
+1 on Bar Keepers Friend.
This is the BEST for a SS pan of any quality. It does not scratch the surface and actually restores the surface to new. A little elbow grease is required but it works very well. I used on All Clad pans after I burned olive oil in it. Left a brown coating that will not come off with regular washing. |
The first time I did this I took it to a restoration shop where they blasted it with plastic beads (or walnut shells, I don't remember exactly). The second time I did it I had my own blasting cabinet and i used glass beads. Big mistake. They cleaned the burnt rice off, but left a rough surface that I had to polish out by hand.
19 years and 17k posts...
Hot water, Krud Kutter and a scotch pad!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
