Anyone know how to tune a small Honda engine?
I have a Honda snowblower that is idling unevenly. It starts fine, but it continually revs up and down. When I speed up the throttle, it still does this. It also is backfiring during these cycles. It seems the only time it evens out is when the engine is under load, moving a lot of snow, that it levels out. I think this Honda engine has a governor that kicks in during this period. I have cleaned out the carb and removed all the old gas. Even ran some Sea Foam through it to see if this fixes it. Any other thoughts?
Petie3rd
do you have any dogs?? or cats??
If you do some more investigation, IE remove the top cover of the engine where the pull starter is , you should find a plastic wing inside the housing, this is the governor it is attached to a spring and it works by being blown closed by the speeding up of the engine. Anyway if there are debris inside the cover they may be blocking its travel, usually dog or cat hairs or even a rodents nest. Please post if you find anything. Also if you took the carb off the engine its quite possible that the return rod isnt in the correct hole or the return spring may also be incorrectly positioned. See if adding some spring pressure changes its operation. NOTE the way you describe the operation sounds about right though the throttle is probably moving too far either way. The motor should speed up then slow down and continue this way though not with huge RPM changes, till you open the throttle and then put the engine under load then it should operate at more or less constant speed also held in check with the same governor so it wont over rev
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 02-14-2010 at 06:29 PM.. |
canna change law physics
Replace carb. Honda carbs do poorly with E10. Try to find 100% gasoline.
I have a couple of hondas than need new carbs, plus my dad's powerwasher.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Detached Member
Thank you for that Red. I have a Honda 2000 watt generator. Where can you buy 100% gasoline in Los Angeles, local airport, maybe race gas at Willow Springs, but that's like 60 miles away?
Oh, and what's a snow blower? Is that like snorting blow and getting a hummer at the same time?
Hugh Last edited by Hugh R; 02-14-2010 at 07:15 PM.. |
Step 1 is buy Briggs & Stratton if you only can access E10. Race gas, Av Gas, not cheap. The problem is an air leak. I've tried fixing mine, but no good. I think the needle valve needs replacing. The carbs are available online for about $60.
Think I have found the problem. Thanks for directing me to the eventual source.
![]() If you see that fine spring end, it must of come off during my rebuild a few years ago. Looks to be some kind of dampening spring for the governor. This is what was moving back and forth causing the surging. If you look below it, you see a small black tab that the end of the spring hooks into. Thanks again. |
Senior Member
We need photos of this "snorting while getting a hummer" activity to make sure!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
this problem sucks. I encountered this issue on my honda odyssey for several times. got to replace some honda odyssey parts before the tuning was done.
Hi there man. Done with this? Are you referring to your Honda odyssey engine?hmmm..Guess a lot of honda odyssey owners are having defective honda odyssey parts. I guess honda manufacturers should take a closer look on their parts.
