Zink Racer
Did I fry a circuit breaker?
My 10+ year old washer was making weird noises the other night and the lights in my crappy late 50's house were pulsing with the washer. It finished and the washer smelled like burnt wire. I bought a new one today and it works fine but now the lights are still making a slight pulsing when the washer was agitating. Obviously the breaker isn't tripped but might it be damaged? Is there another explanation? I don't want to have to do laundry only when the lights are off and I also don't want the old crappy house to burn down. At least not with me in it.
Jerry
983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4
Old 02-22-2010, 09:39 PM
aways's Avatar
Your circuit breaker is either "on" or "off". I don't think that's the problem. Could be that you've just got too many loads on the same circuit.
commandant of the compound
Old 02-22-2010, 09:52 PM
Slippery Slope Victim
NY65912's Avatar
The washer motor is pulling more amps than it should.
The breaker as stated above is either good or no good.
The motor is bad or you have too much on that circuit.
Mike˛
1985 M491
Old 02-23-2010, 04:00 AM
Did you get the memo?
onewhippedpuppy's Avatar
Try turning off most things in your house, then see if the lights still pulse. As others suggested, you might have one particular circuit overloaded. The wiring in older houses is usually pretty marginal.
‘07 Mazda RX8-8
Old 02-23-2010, 04:06 AM
david914's Avatar
Could be a number of different things. Loose wires in the breaker panel and/or meter can, lights on same circuit as washing machine, inadequate wiring to washer.
Do the lights in your house dim/pulse when another major appliance (air conditioner, refrigerator, stove, etc.) turns on?
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 02-23-2010, 04:17 AM
UnRegistered User
billybek's Avatar
Check all the connections to make sure they are all snug (the supply leads will be be hot so be careful). Check the voltage that you have in the home line to line, line to neutral and line to ground. Check to see that there isn't one side of the breaker box that is supplying more loads than the other (balanced load).
Sometime, breakers do go bad. I had to replace the 100 amp main that supplies one of the panels in my home a couple of months ago.
Bill K.
Old 02-23-2010, 05:17 AM
You do not have permissi
john70t's Avatar
If one circuit is affecting another, I'd suspect bad grounding and/or a faulty panel.
That breaker should have blown when too many amps were being pulled. It didn't.
It needs to be modernized, and probably a new line run to the washer. I think new dryers also now require a 4-wire supply/outlet instead of the 3.
This isn't something to ignore. Get it checked out by licenced, certified proffesionals!
One thing that helps is to trace back the runs to the box and label the wires and breakers. Breakers need to be sized to the wires and outlets. I (think) the maximum number of outlets is 8 or twelve on one string, but less is always better. Aluminum wire mixed with copper has a reputation of causing big problems. All the major appliances should be on their own dedicated circuits, and there should be only one wire going out from those breakers.
Old 02-23-2010, 07:35 AM
If this is happened (dimming lights) suddenly (started with no changes) you have a problem. Obviously your washer is not on a dedicated circuit.
How dim do the lights get? I don't think induction motors like voltage sags.
Rick
88 Cab
Old 02-23-2010, 08:17 AM
bivenator's Avatar
Do not ignore, seek professional help, see thread on My house burned down tonite.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 02-23-2010, 09:05 AM
dimming lights is a neutral problem. is it only affecting a single circuit or multiple circuits in the house, i couldn't tell by your post. find the circuit the washer is on and determine what else in on that circuit. on the plus side, your old washer may still be in usable condition.
Chris
the more i learn, the less i know
Old 02-23-2010, 09:12 AM
T77911S's Avatar
as others have said. look into bad connections. mine would dim everytime the ac came on. i found a brokrn lug in the meter base, neutral i think it was.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-23-2010, 09:50 AM
Slackerous Maximus
HardDrive's Avatar
I can feel your pain man. Our house was built in 47. I swear, the post war houses built in the Seattle area were the biggest POS on earth. Just junk. We just spent almost $30k replacing our electrical system
We had to remove 2 driveways, landscaping, and trench 170ft to lay conduit and bring in a new feed. Total nightmare.
2014 Cayman S, PDK
Make Bruins Great Again
Por_sha911's Avatar
Do you know if you have AL wiring? If so, you have a major and much needed repair due yesterday.
Hijack but related: my lights dim slightly for just a split second when my 4 Ton HVAC unit kicks in. 25 YO house. I was told this is normal. Was I given bad info?
Joe
Old 02-23-2010, 01:29 PM
Used & Abused
Normal. Though you can add a start capacitor to the A/C unit to help with the dimming lights. An a/c unit on startup pulls more current than the utility/panel can deliver. It's completely normal though.
On topic: Assuming the lights are on a different circuit, you most likely have a loose neutral or ground. It's most likely in the panel too. A good electrician should be able to find the source of the problem in under 2 hours. IMO I'd go this route if I were you.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 02-23-2010, 01:45 PM
