RETIRED
Joe Bob's Avatar
Stupid idea corner....trailer trash toy hauler.
So a local guy has two old boat trailers....MAJOR cheap.....both are dual axle and surge brakes.
Has anyone ever welded two butt to head and then done a deck on it? I was thinking of doing a cabin up front with the rear for the 911 or the 914/6.....ala CSOB Toy Hauler.
I would remove one axle on the front trailer and use leave the remaining front one for weight support. Dual axle on the rear for the heavier car deck....
Am I smoking crack or is this something that might work....hey, it's cold, snowing and there no warm betty's in sight....
Old 02-27-2010, 07:12 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
dude you should have called me.. We're partying like rock stars up here at the lake!
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-27-2010, 10:43 PM
RETIRED
Joe Bob's Avatar
Yer always busy.....
2012 ML350 3.0 Turbo Diesel
Old 02-28-2010, 03:30 AM
RETIRED
Joe Bob's Avatar
One trailer was too narrow, the other was fine....6 feet 2 inches wide so my 911 fits as well as the 914/6. It's 20 feet long with about 18 feet of useable deck.
I'm going to pick up some 2.5 or 3 inch ID steel, weld cross braces and then lay a double layer of 3/4 inch marine plywood deck.
I'll decide later if I will enclose it....probably will. It's dual axle and rated for 6500 lbs. Paid $100....some surface rust, surge brakes and I spent an hour cutting the boat crap off.....maybe 8 hours more work, 300 in steel and plywood and I'll have a nice car hauler.
Old 02-28-2010, 04:36 PM
Z-man's Avatar
Not worth it. You are better off getting a purpose built car trailer than trying to convert boat trailers into what you need.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 02-28-2010, 04:40 PM
My thoughts exactly Z....
Old 02-28-2010, 04:41 PM
vash's Avatar
seen one. it was a pop up camper with a flat bed up front big enough for a car. the thing was a behemoth.
poof! gone
Old 02-28-2010, 06:31 PM
Run smooth, run fast
Heel n Toe's Avatar
If you do it, make absolutely sure when you weld it together, the axles are perfectly parallel, or it may track a little funny.
- John
Last edited by Heel n Toe; 02-28-2010 at 07:40 PM.. Reason: clarity... insert missing verb
Old 02-28-2010, 07:06 PM
RETIRED
Joe Bob's Avatar
I'm just gonna add a beaver tail, cross members and the deck. I have two kids where I live now for the grunt labor. Welding ain't hard. I can do about 1-2 hours then I gotta lay down.....cause my back flares up and I'm not taking any pain killers.
I have the steel wholesaler chop the cuts for me. the mill charge is worth it to get the angles cut straight and true. The axles will stay where they are and I won't modify them....
Old 02-28-2010, 07:23 PM
JW Apostate
trekkor's Avatar
My car trailer was a boat trailer.
I say do it!
I want to modify mine, but an enclosed trailer is in my future.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 02-28-2010, 07:40 PM
RETIRED
Joe Bob's Avatar
Who did the mods? Got any pics you can share?
Old 02-28-2010, 07:44 PM
JW Apostate
trekkor's Avatar
I did all my own work.
I cut off the bunks and bow stop.
Fabbed up a metal frame and built a 2x12 pressure treated deck.
There is a big locking box on the front.
Ramps attach to the back and I have removable side gates that I use when moving materials or making dump runs.
As long as you do quality welds and don't over load the trailer you will be fine.
I've had 5300#'s of gravel in my trailer.
It weigh's about 1000-1200#'s empty.
KT
'01 Boxster
Old 02-28-2010, 08:30 PM
Parrothead member
VINMAN's Avatar
Go for it Mike! I like homebuilt stuff. Anyone can go and buy something. I appreciate sweat equity more.
Vinny
Old 02-28-2010, 08:38 PM
DanielDudley's Avatar
Just make sure you don't have negative tongue weight with a 911 on it. Bad stuff.
Old 03-01-2010, 04:33 AM
Double Trouble
targa911S's Avatar
why am I hearing banjo music?
Old 03-01-2010, 04:46 AM
RETIRED
Joe Bob's Avatar
Let's see.....800 with a little sweat equity versus 2500-5000 for a new one. My final conversion isn't that stoopid.
The original idea of tying two, together was.
Old 03-01-2010, 05:48 AM
JW Apostate
trekkor's Avatar
I want to add an over the hood, removable tire rack for mine.
KT
'01 Boxster
Old 03-01-2010, 09:58 AM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
reading this thread got me thinking...has anyone converted a travel trailer (like a 20-30ft 5th wheel) into a car hauler in the back with living space in the front, or even with the back cut off so bigger vehicles like a pickup truck can be loaded in the back? Older RV's/travel trailers can be real cheap, compared to an open trailer (gooseneck) of the same length...
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 03-06-2010, 10:16 AM
RETIRED
Joe Bob's Avatar
I've seen it done....you need to compensate for the added weight by moving the axles back towards the new center of gravity....
Old 03-06-2010, 03:25 PM
Make you sure get one with a serious frame under it.... Most of them are a little wimpy in the frame department....
Old 03-06-2010, 04:48 PM
