'73 911 T Targa
Are Audi questions allowed
I need help with an Audi quesiton, but I haven't found an Audi forum that's as active as this one. I have an Audi TT that came with run-flat tires and no spare. It's got a space for a spare, but I'm told no spare, donut or otherwise exists for the car as it was designed around the run flats. Does anyone know if the collapsible Porsche spares will fit this car? I mean it's all about lug nut spacing and brake clearance, right?
TTs are Golf-based, so I'd guess you'd be better off checking that angle.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
The Audi products are 5x112 or 5x100 bolt patterns and use a 72.6mm center bore. Porsches are 5x130 bolt pattern so they won't bolt on.
There's a couple of good sites to try, my preference is QuattroWorld.com. It's an offshoot of the old AudiWorld site but in a format that the users prefered. Just celebrating it's one year anniversary. Some of the regional forums are better than others, so that part will depend on where you live. But the model specific forums can get pretty robust and can answer a lot of your questions. The TT forums can get pretty lively at times.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
1988 911 coupe 1970 911t project 2012 Golf R |
Something about teaching an old dog new tricks.
It's still pretty active. Rich
The car definitely came with a spare.
Go Speedracer, go!
I go to Audizine.com sometimes too.
1981 SC ROW Coupe |
winter
You may want to join one of the quattro lists at audifans.com. I use the S-Car list a lot for my S6 Avant. A lot of very serious DIYers on those lists.
Good luck. --- Tom '75 targa |
AKA SportsCarFan
I own a 2004 VW R32. It came without a spare -- it came with a can of stop-leak & a compressor. I read on a VW Vortex forum that an Audi TT spare would fit in the spare tire well of the R32, because the R32 is essentially a TT platform. I purchased a TT spare it did indeed fit into the space beneath the carpet in the luggage area. Problem is, the spare will only fit on the rear because the R32 front brakes are too large. So if I get a flat in front I will have to change 2 tires, but at least I now have a spare.
So at one point TTs must have had spares, because I bought one. Hope this info helps.
Doug Miller 1988 Guards Red Carrera |
a.k.a. G-man
This should be in OT.
Сидеть, ложь, Переворачиваться |
Is the Audi black? If it is...well...you know...
Pre Registered
Silence!
No "sports purpose" for you! Tim |
