UnRegistered User
billybek's Avatar
MIG Welding. Any tips?
I was given a small Miller 135 wire feed welder by the material handling guys at work for use in my shop/classroom.
I have been experimenting with it for a few hours when I can spare some time and the thing I have the most trouble with is seeing the puddle.
I have done a fair amount of stick welding in the past, but seeing by that large tip on the MIG handle is tough to do.
Any tips on this?
Bill K.
Old 04-24-2010, 06:32 AM
Senior Member
Push the wire out a bit and make sure that you have the gas coming out of the tip enough to flood the weld area.
Old 04-24-2010, 07:20 AM
MAGA
Tim Hancock's Avatar
If you can't see, maybe you need a lighter welding mask glass.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 04-24-2010, 07:44 AM
UnRegistered User
billybek's Avatar
It is not so much seeing through the tint as being obstructed by the tip itself. I did install a 1.5 magnifying lens inside the helmet. That might help a bit too, I haven't tried it yet.
It is very possible that it is just positioning, but where (except on a bench or fab table) do you actually get to easily see your work without some sort of body contortionist exercise?
I tried a bit of angle iron, did a few lap joints and some sheet metal. with the low setting for the sheet metal and the slow wire feed maybe I am too close in.
Bill K.
Old 04-24-2010, 08:42 AM
Formerly reformed
Your angle may be off. I usually hold it around 45 degrees depending on what type of joint I'm looking for and what direction I'm moving in.
1968 911P (Paperweight)
Old 04-24-2010, 10:03 AM
Schumi's Avatar
Theres an easy solution-
scrap the MIG, get a TIG.
M
Old 04-24-2010, 10:16 AM
Formerly reformed
I neglected to mention that the helmet does play a major part here, especially for people who haven't been doing this for a decade. I'm using a Speedglas auto-darkening helmet- it's the best one I have used to date and has really improved my welding in terms of both effectiveness and efficiency.
Old 04-24-2010, 10:41 AM
Certified Pre-Owned
BGCarrera32's Avatar
In a way it sounds as if you're trying to weld material thinner than in intended (although it is a 135), or most likely your wire speed is too slow and you're feeling the need to keep the tip really close to the workpiece. Try experimenting with upping the speed a bit so you can hold the torch back from the work 1/2". Also check the feed rollers in the unit to make sure the wire is not slipping or anything is obstructing the feed.
When I weld material say 3/16"-1/4" thick, I drop my left index finger under the torch towards the back of the tip using the outside edge of my left hand to steady the torch, run the torch with my right hand and push the weld, seeing above it clear as day. Hope that makes sense...
When you have a good weld bead going- 2 things: 1) you should see the heat on the back side of the part when you flip it over, 2) it should sound like sizzling bacon when you weld.
'84 Carrera Coupe
Old 04-24-2010, 10:50 AM
1980 911 SC
Not trying to be a smart a$$, but this reminds me of an interesting moment. I couldn't see worth a hoot when I got my Miller 140. Turns out my helmet was filthy, after cleaning the lense all was better.
Instead of looking over the top of the tip, IIRC, I look at it from the side.
Life's a Beach
Old 04-24-2010, 11:20 AM
Zeke's Avatar
Chief has got it. Keep the angle of the torch at optimum, about 30 degrees from vertical, and look in from the side. Most welders "push" the puddle while MIG welding, so if you can lean over to the front and side, you should see all you need to see.
The motion, or weave pattern you use will also help. There may be instants that the puddle is obscured by the gas nozzle on the torch, but you should see the tip of the wire as it deposits in the puddle most of the time.
I like a short stick out and I have a couple of nozzles that have been modified with the band saw so I can get in there and still see. You may want to shorten your nozzle a bit and see if it still surrounds the puddle with gas. If there is much air movement near the weld, it gets harder to run a good bead.
Or, you can switch over to wire feed with no gas and flux core to practice. More splatter, but same principles. The wire feed nozzle is much smaller; it's just a protector.
Old 04-24-2010, 11:34 AM
UnRegistered User
billybek's Avatar
I was able to burn a bit more wire this morning.
The magnifying lens and moving to the side seemed to help a bit.
I think getting wire speed and voltage settings correct for the material being worked is an experience thing that will get better with time.
They have a free seat program for instructors so I will have to make contact with the weldors here and see if I can sit in for a few sessions.
Bill K.
Old 04-26-2010, 09:21 AM
Thats one toy we don't have..... Yet....
Old 04-26-2010, 10:22 AM
Schumi's Avatar
I've 4 years experience TIG welding thin wall (.032") alloy steel upright structures and space frames...
I can't stand not having that sort of control over the welding process. And for thin tube and sheet structures there is no alternative.
M
Old 04-26-2010, 11:18 AM
Zeke's Avatar
Novice welders tend to go too fast. That was my problem for sure when I was doing stick. Fusion is a balance between not enough penetration and burning through. At least AFA sheet goods go. If you have a tendency to burn through, don't speed up, turn the current down, poke the wire in closer and/or use a bit more angle.
Old 04-26-2010, 11:25 AM
