Pool filter: glass iso sand?
I just started up our pool after the winter. One of the issues I had was sand being blown back into the pool from the filter (Pentair 22").
Since the sand is now 5 years old I'm contemplating the idea of replacing the sand with glass beads, hoping to get rid of the mentioned issue at the same time. Any ideas?
Champaign and Burgundy 3.2 (1986) Ex-C4 91 Ex C4 93 A8 3.0 TDI X5 |
Detached Member
Our HOA waterfall had sand and it was pretty mucked up, the former pool maintenance guy replaced with the glass bead stuff and it works better.
Hugh |
If sand is coming back into the pool, most likely you have a hole(s) in the laterals at the bottom of the filter. Glass beads will not fix that, plus glass beads may cause further damage to both the laterals and the vessel itself when you backwash. The laterals at the bottom are replaceable. Biggest hassle is removing the sand, a good wet/dry vac will do the trick. Once replaced, refill the filter vessel half full of water before you replace the sand, this will cushion the sand as it goes to the bottom. I do not believe the glass beads will give you the cleaning ability that the sand will, you need .45 - .55 micron sand.
Senior Member
I replace the sand in my unit every 5-7 years...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Tx guys, I'll need to check the lats again. I hope my vac is strong enough.
