AutoBahned
Feedthru or Grommet or... something
I'm looking for something to fill a large hole in sheet metal but with a small hole in the middle of it.
I'd like something that looks like a rubber grommet around the outside, with an OD of ~ 1" (i.e. the hole in the sheet metal I want to fill is 1" dia.) but thru the center of it I want to run a tube 1/4" in dia. (or I could cut a hole that size if the thing is solid) this is for an electrical wiring run I'm doing in a VW Vanagon - I had to drill 1" holes so I could get polyethylene tubing run (it protects the actual 12 Ga. wire from harm, shorting etc.) so, what are these things called and where (what type of store) would carry an assortment of them? thanks! |
78 in a '71
Grommets, Ace
Best, Tom
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
Senior Advisor
Look at the aircraft spruce Webb site and search for firewall grommets. like this one:
![]() Or you can fab something like that. That one covers a 1 1/4" hole.
08 Cayenne Turbo |
Formerly reformed
Yep. Grommets. There are two of them just about how you're describing that hold the license plate wiring on the rear bulkhead of a 914. Think Ace might be your best bet because I know Lowes and HD don't have near the stock of those items that they should.
1968 911P (Paperweight) |
AutoBahned
ok, True-Value does not have them.
I found pics of things that will work - called cable grommets, or feed-thrus I am looking for something with a mostly filled-in interior - regular grommets ("thin") won't work. I'll try the local electronics store & see what they have. I don't see anyone saying "your FLAPS will definitely have these".... |
78 in a '71
Best, Tom
Use a 1 inch rubber sheet metal plug, cut your center hole, and put a 1/4 inch grommet in it.
Brent Early85 944 LM6Y Paint Code |
AutoBahned
that would be fine IF I could find a rubber sheet metal plug anywhere in this town...
wasted entire AM on this ID = 3/8" ; OD = 1 3/8" and rubber or other flexible material with a groove that will fit sheet metal - why is that so hard to find around here? |
Seldom Seen Member
I'm looking for essentially the same thing - rubber grommets for where a brake line enters and leaves the passenger compartment. Can't find them yet. May have to order online.
Why do things that happen to white trash always happen to me? Got nachos? |
You can get them here McMaster-Carr
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
AutoBahned
thx, but none of those meet the ID & OD specs.
I discovered a new term to spend time on searching... "body plug" |
Seldom Seen Member
Here's what I have to get: Product Detail
AutoZone, and presumably other auto parts stores, has packs of random sized grommets. I'm going in just a minute and will look for your specs.
Senior Member
Why do you keep posting questions here? You act like you know everything already?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
AutoBahned
hmmm, brake line grommets -- that's an idea
I was at AutoZone, Napa, & 2 other FLAPs this am; also 3 fastener houses and a couple of hardware places... part of the problem may be that the clerks can't think beyond a particular "name" for the time - i.e. can't think of it unfortunately, the days of open bins are about gone I'll try a VW and misc. parts place on the other side of town tomorrow & maybe hit some autobody shops... Joe - please go back to PARF |
Seldom Seen Member
5/8" was the biggest at AutoZone.
Mcmaster has one in the "push in military spec grommets" #9307K76
fills 1" hole in panel, with a 1/4" opening. Will that not work? Pack of 5 is $5.34
AutoBahned
unfortunately, I need one for a 1 3/8" dia. hole...
and then the ID has to be 3/8" |
Try page 3748, snap in grommet #63595K33
AutoBahned
thanks! that's the closest thing yet
You could just use 1" conduit caps that they use on Schedule 40 conduit. The plastic will be large but will deform enough to fit 1" hole. Then drill or hole cut a 3/8" in the middle. If you wanted to get really artsy, you could pop rivet an aluminum plate to the bulkhead and hole cut the 3/8" in the middle of that.
