Licensed User
Shuie's Avatar
MIG welder for home/garage projects
Does anyone here own one of these?
Miller - MIG Welding - Millermatic® 140 with Auto-Set™
I have a few projects in mind that are going to require buying a welding machine. The projects are mostly 2" square tube, both carbon & stainless.
I really like the idea of the auto-set function for the wire speed on the Miller. I don't think I've seen this feature on another machine. Even though I wouldn't need it, I also like that it has the capability of attaching the additional gun for Aluminum wire.
What are the limitations of a machine like the 110V Model 140 for home use? Should I be leaning more towards a 220V, or the dual voltage (110/220) Model 211 instead? What kinds of projects could I get into that will make me wish I had a bought a bigger welder than he 140? I only want to do this once, but I really do not want to go through the exercise of installing a dedicated 220V receptacle in my current garage for something like the Model 211 unless I will need it.
Old 05-22-2010, 11:27 AM
1980 911 SC
I asked the same question http://forums.pelicanparts.com/paint-bodywork-discussion-forum/485108-millermatic-140-auotset-worth-extra-money.html
The work I did on my 911 was handled very easily with the 140, the voltage very rarely was turned up past #2 or 3. I didn't know it can be used on carbon or stainless. I am still learning myself. I would find a dealer that sells them and go in to talk with them. The salesmen are usually welders themselves and can answer a lot of questions. It is also handy to have a shop or person to go to when you have questions, they bailed me out several times helping me with technique etc.
If you plan to weld big and heavy I would go with the 180. Hooking up a 220 source is not a big deal.
Life's a Beach
Old 05-22-2010, 12:19 PM
Welders are like other tools, buy the biggest you can afford. You'll use it one day. I use mine for all kinds of little projects.
Old 05-22-2010, 12:24 PM
I highly recommend buying a good 110V unit with gas. You can use the flux core wire (as I have done for years) but having the gas makes your welds much nicer.
110V is nice because you can be mobile with it. This may not seem like a big deal until you realize that not all projects are within 10' of your 220V plug. Try going to Home Depot and asking for a 50' 220V extension cord
IMO, if you're going to get into big structural stuff that is thicker than 5/16" or whatever the limit on the 110V setup you're looking at you should hire a pro anyway. 99% of home projects can be done with the 110V.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 05-22-2010, 12:58 PM
Zeke's Avatar
If you have the money, get the dual voltage machine even though you don't have 220 in your garage. There will come a time when you can hook up to 220 and do thicker material for yourself or others. I've made enough money on the side to pay for all my welding equipment.
Old 05-22-2010, 12:59 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I have the Millermatic 211 Autoset with the dual voltage setting and I absolutely love it. Haven't had to hook it up to 220v yet but I know when the time comes I have the machine for the job. Had a Millermatic 130 (or was it 135) before they came out with the 140/Autosets and although did not need it at the time I felt that if I ever had to fix or make something heavy duty I would've wished I had the 220v.
FWIW I've bought my last two Millers from this place...great prices and customer service.
http://store.cyberweld.com/mimigwe.html
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 05-22-2010, 01:00 PM
And bigger isn't better. You'll need to have a very low setting for sheet metal. A machine with a wide range of heat settings is much more useful to the home mechanic than one with the biggest rating.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 05-22-2010, 01:01 PM
DanielDudley's Avatar
If you think you would ever like to build a trailer, or weld a truck frame or chassis, get the 220 model. I have had a 110 volt Miller for over 20 years, and it will still do all the welding you would need to restore a 911, but it won't do the above.
Old 05-22-2010, 02:42 PM
Scott R's Avatar
I've used my 220 mig once in the last 4 years, it was to weld a power steering plate/bracket to my Land Cruiser frame. Beyond that it just sits as the 110v mig/gas welder does all of the work.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-22-2010, 03:59 PM
Originally Posted by milt View Post
if you have the money, get the dual voltage machine even though you don't have 220 in your garage. There will come a time when you can hook up to 220 and do thicker material for yourself or others. I've made enough money on the side to pay for all my welding equipment.
+2
I have one of each.
Old 05-22-2010, 04:23 PM
We have 2 220s in our shop. A miller that sees most of the use and a lincoln with a spool gun for aluminum. For the thin stuff you flip to low range and set it on 1 or 2 and it's just fine.
You might check but Im not sure about welding stainless with a mig....
Old 05-22-2010, 05:53 PM
Licensed User
Shuie's Avatar
Thanks guys. I really appreciate the help.
I definitely want a machine big enough to handle a trailer/carhauler project, or a tube framed car build. Actually, the first project I had in mind was to strengthen or add support crossmembers to the 2" square tube subframe of a car I have now. If a 110V welder is questionable for this type of project then I'm sure I want to buy something like the dual voltage Millermatic 211.
I've never welded stainless, and I have no real experience with these welders, but Miller and Hobart list stainless wire in the specs on their websites for even the 110V machines.
....from the Miller website....
Uses 4 or 8 in (102 or 203 mm) spools and can be set up to weld with wire sizes .024 - .030 in (0.6 - 0.8 mm) mild/stainless steel and .030 - .035 (0.8 - 0.9 mm) flux cored.
Note: Auto-Set is calibrated for .024 and .030 mild steel wire and C25 shielding gas (75% Argon, 25% CO2). Use manual mode for broader applications with mild steel, or to weld stainless steel or flux core.
Old 05-22-2010, 06:35 PM
I don't think you will regret going dual voltage.
I've used a fairly new millermatic 220... Damn fine machine. Not sure its as smooth as dads from the late '70s... But its still a good welder. Dads buddies all covet his old Miller....
Old 05-22-2010, 09:21 PM
Licensed User
Shuie's Avatar
What does he have? I'll go vintage if I have to. Im all about the old stuff
Old 05-22-2010, 09:28 PM
He has a Millermatic 200. Like I said its OLD... He bought it used when he started his body shop in '83-'84. It got used quite a bit there and then is used at least once a week in the sign shop. Still welds like a dream. Like I said... I prefer it to the newer ones we had in the ag shop at school.
Not ours but one like it...
Old 05-22-2010, 09:35 PM
Senior Member
Sid,
Son, you need to rethink some of your comments!
I am still using some of the tools that my Great Grand Father made by hand (he was a blacksmith) back in the 1880's. Thats OLD.
A Miller welder made 20-30 years ago is not old, its just getting broken in and is better quality than 95% of those made these days.
Old 05-23-2010, 09:38 AM
stainless is not a problem with MIG, for best results use stainless wire and the proper gas mix.
Jeff
Old 05-23-2010, 10:39 PM
