"YOU CANT RACE A CAB."
call me tuesday for our pool guy. w/a olympic size lap pool and mine to deal with we have this down to a cheap ass science.
backwash for about 3 minutes. run pool for 5 minutes. backwash 2nd time. do this once a week. 3 tabs chlorine a week buy a big ass bucket cheaper. clear all vegetation that drops crap away from pool as best as possible. depending on how pool situated and how storms come thru will be the unknown factor on how hammered yer pool gets w/crap during monsoons. the worst storms ever maybe 15 minutes clean up for me. always keep baskets clean. drink beer. |
I took a sample to the local pool supply store today. They said the numbers weren't nearly as bad as my test strips (which I bought at the same store) said, but that CYA was still pretty high. He just said there was nothing I could do about it until winter, as it's now too hot to drain and refill a plaster pool. So I'll keep an eye on things and maybe do frequent backwashing and switch to non-stabilizing chlorine tabs.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
if ya need yer tile bead blasted(they drain pool about a foot and use an inner tube) yell. it will remove hard water deposits(calcium) for about 3-4 years. yell.
Canadian Member
Some of these chemical guys make it so difficult. My own father struggled with his hot tub for years before he drained it and left it empty. Wouldn't listen to me because the 'pool guy' said.... Never drain ours; well I did once and never again. good luck |
canna change law physics
UJO has it nailed.
I quit using my chlorine dispenser as the tabs turned into a 3 inch diameter, 10 inch long block. My pool is 27,000 gallons. And lots of sunlight and high temps, you use more tabs. Depending on the time of year, I toss in 1 to 3 tabs into a skimmer, about twice a week. I check levels about once per week. I adjust ph with muriatic acid from home depot. I don't worry about the rest, except phosphorus. Besides, the levels are pretty close. Salt doesn't seem too reliable here. Everyone with salt ends up with black algea. Do you have a pool cleaning robot? It has it's own pump. I pull the cleaner hose and use the system as a stirring mechanism. I turn it on, and then pour in the acid. Do not put acid in the skimmer, as it can release stuff from the pumps. I also use a giant paper filter. Works fine. Better than sand and easier than DE. DE can create cleaner water.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Canadian Member
Oh, I forgot a pic... cheers!
Yes, I have the pool robot. He does very well. I did a slight backwash today, but a lot of DE came out with it, which makes me think it was too soon to do that. Still love swimming at night. Haven't turned the a/c on yet and the pool cools me off for a good hour still.
rick i have had pools in my life all my life. be it my parents or mine.
if yer blowing de out when backwashing 2 things are happening. its wayyyyyy overfilled or yer laterals inside filter are busted. if you sweep pool today and find a bunch of clouds after brushing. yer laterals are wasted. this is common on older filters. now if ya have laterals busted yer at corp decision time................ de more expensive but better filtering. pain inda butt to remove from filter. sand cheaper less filtering and easy to suck out with wet dry vac. i use sand cuz its cheap/easy to remove from filter w/wet dry vac. since i have so many interests in life and its go go go all the time, i dont want to become a prisoner to NOTHING! barracuda buzzes around from 12 midnite to 830 am. everyday. im nice to pool once a weekend day and run for 24 hours and then backwash twice, in the event of haboob(monsoon-guac-ca-muggy) a storm with 100mph winds going sideways and a microburst over yer pool it sure as hell isnt gonna matter if ya have sand or de. now since us natives like teaching lil grasshoppers our tricks to make life easy. spread de all over perimeter of house or buildings. cheap ass simple bug killing idea. bugs HATE de. under microscope they is lil salt like crystals that get in their lungs and kill them. kind of like miners lung to humans. now if yer gonna stay in house and ya wanna upgrade cuz plaster is cracked, go to pebble tec like mine. ie. another layer over plaster. ZERO MAINT. so for drill heres how i designed mine for anti storm zero maint or 5 minutes maint. pebble tec barracuda simple replace giant condom maint caretaker pop ups(water flow pushes debris towards drain) and off steps sand filter had mix salt/water/electric chlorinator and they take a crap too soon. went to 3 tabs a week in basket. i havent bought a test kit in years. if i see algae green or black i super duper shock it for a coupla days. happens usually during monsoons a coupla times from excessive dust. drink beer step away from maint. fill pool high now to loosen debris on tile and brush tile after 6 pack and step away. Last edited by ODDJOB UNO; 05-31-2010 at 05:01 AM.. |
Senior Member
You are making this harder than it sounds. Drain the water every 5-10 years, period. So much evaporates here that its not really needed even that much. As well I backflush every 2-4 weeks, not any more often. Then do it until the water runs clear and shut it off and enjoy. I put 4 tabs in my pool, two in the floater and two in the bucket and thats it. Every month or so take a water sample down to Leslies pool supplies and they check it for me FREE. Do not use those crappy self testing things, they are wildly in-accurate. Everytime they tell me its fine or close. Now as for running the pump motor, I used to do what they say and run it 1 hour for every hour of sun. Bull Hockey. Backed it down to 6 hours and it did fine. Three years backed it down to 3 hours and its still doing fine with NO change in the readings on the water checks. I turn mine on about 6 am and run it to just before 0900 when the power gets expensive. As well get some acid and shock flushing agent to have around just in case. If you wake up one day and its started to turn green, then hit it with the shock and acid and turn the pump on. This is not rocket science, its hole in the back yard with water in it! Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I never thought about your dust/sand/windstorms out there. A sand filter might be the most practical.
Well, I wouldn't be worrying about it except that my CYA level is through the roof and there's no way to correct that without a drain and refill. CYA does not evaporate and there's nothing you can add to dilute it other than more water, which I can only do if I drain the pool. I haven't added chlorine tabs in 10 days and it still has too much chlorine in it.
A Man of Wealth and Taste
When I was growing up we had a pool and at my last house I had one for 13 years. Always was a DIY affair..
My Dad had his BS in Chemistry from Wayne State...his method of treating pool water was to dump in about 1/2 gallon of Chlorine every week and a 1/4 of a gallon of acid every month or so..I never saw him test the water... That was generally what I did..except I had the Automatic Chlorinator at the Filter...just drop in 10 or so tab's once every 3 weeks...Acid once every 6 to 8 weeks. I had a DE Filter...once every 3 to 4 months I would pull it apart and wash the Filter elements with a hose...and when done dump about 12 lbs of DE in the Skimmer... For cleaning I had a Kreepy Crawler...with a Catch Basket on it...so I wouldn't have to constantly be opening the basket on the pump. Never drained the water in 13 years...never really had an Algea problem either. I had one spot on the steps that used to get the crude but that was because the Pump outflow into the pool didn't push the water out, it was just a small area of still water. That was a design flaw when constructiong the pool. As you add chemicals to the pool water the Chlorine becomes a solid in the water and the water gets harder and harder..and as time goes on it takes more and more chlorine because of that hard water to keep the water stabilized and thus algea free. The only time I really had to work the pool was after a big windstorm..then it would take a coupla hours to get the leaves outa the bottom..For that I had one of those catch baskets with a graden hose attached...that got all the big stuff and then you could go back with the vacume on a pole..to get the dirt.. I do miss that pool...I was in it everyday in the summer. the water would stay between 80 and 85 all summer... Here in LV the water gets above 90 in the summer..it is so hot you even need to dump ice into the pool. to bring the temp down..
Copyright "Some Observer" |
One day I should describe the construction of this pool. (16 X 34..6.2 ft deep) ..the pool itself has 56 yards of Gunite with it being 18 inches thick on the bottom...the rebar in the bottom is set 4 inches on center.. The retaining walls are another 35 yards of concrete for the footings. Over 200 yards of dirt and ROCK were removed to put that pool ad garage in the yard.. There is 30 feet of 6 foot high retaining, 110 feet of 5 ft high retaining wall, and 240 feet of 3.5 ft high retaining wall that goes around the pool. The Garden Wall behind the hedge on top is 210 ft of split face CB.
All the electrical was commericial grade, has 3 pump motors..a Jandy remote..with automatic valves to turn the Spa on...The Bronze Statue was 5K, and those Lions heads are Copper..The Coping around the pool was Custom..and cost 4K., tile was 3500, The Ballaster Railing 60 Ft.. and Step material was 7K just for materials..All told that backyard with garage was about 150K back in 1990. I basically subed out all the hardscape and garage. But I did all the planting and sprinklers...13 valves with 360 sprinkler heads..Irtrol commercial 18 station timer. The area from the garage to the driveway in the front is all Turf Block...13 pallets worth...all laid on a 4 inch bed of sand that was compacted by rain..each block leveled to create a flat surface...then dirt is used to fill the honeycomb in the block and it is hydro seeded..after a year it looks just like a lawn...but on you can drive on. I can remember getting behind that Retaining wall behind the pool and using asphalt driveway coating to waterproof that sucker...I did it in July.when it was hot behind that wall. That garage is 750 Sq ft..all insulated and drywalled. 220 electrial with its own subpanel and a 100 sq ft walk in Vault inside.that had a Diebold Bank vault door...the vault was 8 inch CB all cells filled with concrete and it had a 6 inch cement cap for a ceiling..rebar if I recall was 6 inches on center.. BTW the guy sitting in the chair is a relative who lives in London, was part of the IBM team that installed the FIRST COMPUTER AUTOMATED AUTOMOBILE PRODUCTION SYSTEM IN THE WORLD in 1962 for Chrysler, went to Japna and lectured the Japs how to install computeerized auto production systems in the early 60's, was part of the IBM team that went to the USSR to install their first computerized auto system...and has designed/invented the anti=theft system for Aston Martin, Jaguar and Range Rover..you can kill the whole electrical system remotely..and the SOB owes me some money..I own 5% of his comapany which owns the intellectual propery for that system.
Copyright "Some Observer" Last edited by tabs; 05-31-2010 at 04:16 PM.. |
Detached Member
Is too much CYA bad? I thought it just help the chlorine residual. Pool robots are great, I got one a few months ago that will climb the walls to the water line. I should have bought it years ago. Test your make up water at the store to check alkalinity and hardness that it what you're starting with.
Hugh |
THe 911 is actually sitting on a Turf Block driveway...
I think I need to test at least once a week. I live right next to the pool store, but I can't take it to them every week. I think once a month is what they expect. I want my pool chemistry to be right.
Senior Member
Go to different stores on different weeks. Find one by a place you are driving to and alternate if you are that worried.
Detached Member
The wet chemistry isn't all that bad to perform. Once you get it dialed in, it doesn't move a whole lot, at least where I am. If anything, I add a lot of muriatic acid. The alkalinity of my make up water is around 180. If you have alkalinity problems you should use Soda Ash, not baking soda (sodium bicarbonate).
Hugh |
Rick,
Every time you backwash, you'll lose some water. When you add fresh water to fill it back up, you'll dilute the stabilizer. Over time, the level should drop. Once you get the chemistry where you want it, it will stay there. The only thing you really need to check is the chlorine level and the quat level. Chlorine is easy, the pool store will have to do the other. Check the chlorine every day until you get a handle on how many tabs to use and how long they last. With a stabilzer level that high, they'll last a while, unless you swim a bunch or get organic matter into the pool. Take a sample into the pool store once a week. JR |
