LinkBack | Thread Tools | Rate Thread |
Me too.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
The Unsettler
I get the hang every 5-6th refresh/page change/post action.
Same thing at work and at home.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
The Unsettler
just hung for 40+ seconds. Pelican trying to connect to csvta.target.com
It's hanging again for me too.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
No delay in anything in anything this morning except for me to get in gear. Damn booze ![]() ![]()
The Unsettler
Thanks, FWIW if the ad revenue helps offset your out of pocket cost I'm willing to deal with some slowness.
Wayne, Google does an amazing job of indexing the pages. On a few occasions I have googled a "fact" posted on the forum as a fact check. Many time this forum is at the top of the list. The very thing I was going to fact check is the top item. It made me laugh.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Bandwidth AbUser
It's still hanging up. I just had a couple of WSOD's, too. All on the 911 Tech Forum page.
Jim R. |
Hanging up here too.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Bandwidth AbUser
and again. WSOD.
Jim R. |
Very slow today.
Wayne, I wouldn't let this frustrate you in the least. I'm almost sorry I started the thread. We all appreciate Pelican Forums. |
Bandwidth AbUser
yep.
Jim R. |
a.k.a. G-man
+1 on the slowness, today was not a good day. +1 on the not letting it frustrate
Сидеть, ложь, Переворачиваться |
Wayne
Noticing that it's slow at time since I got to work. I decided to check it via my Iphone4... You guess it, the Iphone seem to be faster or you would not be reading this ![]() ![]() ![]() The Iphone is on Rogers 3G System in Canada. Tonight, I'll compare the Iphone to my home computer on Rogers Internet and we'll see. J.J.
The slowness has returned to me as well. As a matter of fact approximately 15 minutes ago the website simply would not come up. And I tried twice, once on IE and once on FireFox.
'17 Cayenne |
Senior Member
Same here with FF. Tried to open a page and it took over 2 minutes to do anything, then popped up just fine.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Slower at work???
-------------------------------------------------------------------------------- Just ran the test page at work; over a second... We are on Fiber going to Ethernet. I'll run the connection test Speedtest.net - The Global Broadband Speed Test tonight a home to see the difference ![]() -------------------------------------------------------------------------------- Put your shade on... Quote: Originally Posted by Wayne at Pelican Parts Also, I can use some additional help to see if we can track down this problem. If you are having difficulty get the forums to load, perhaps you can go to this link: http://forums.pelicanparts.com/test.htm and see if you can load the page. It's forums . pelicanparts . com / test . htm If you can load that page fine, then the database may be having difficulty (that's a static page that doesn't use the database). Also, if you can perform a tracert from your home computer and paste the results here, then that would be useful too. Keep in mind that the last hop on the tracert will not be functional, as my firewall will terminate there. If you don't know how to do a tracert, it's really easy. Go Start -> Run then type command.com. Then type: tracert forums.pelicanparts.com and it will start analyzing the path that your computer takes to reach the forums. Hopefully, it may emerge that one of the big pathways across the country is either clogged or misrouted. Again, here on COX I haven't seen any issues. Thanks, -Wayne Load in .3147893245643 of a seconds (land base Internet)... of course my BBQ timer has not been calibrated for a while so others result may be different __________________ Who Will Live... Will See Das Babe Das Babe Metalberiech
So far so good. I've not been on the laptop much today though. The iPhone has been pretty quick.
... Mes forums semblent beaucoup plus rapide ce matin
