AutoBahned
RWebb's Avatar
CAT 6 DIY - punchdown tool needed?
do I need to buy a punchdown tool to install the connectors onto CAT-6 cable?
if not, any suggestions for the best way to do it for a secure install?
the connectors are RJ-45 IIRC...
Old 04-09-2011, 12:35 PM
RETIRED
Joe Bob's Avatar
Platinum Tools, 706BR-1, EZ-SnapJack Cat 6, Brown, 10 PC, Bulk Bag
This implies, no.....
2012 ML350 3.0 Turbo Diesel
Old 04-09-2011, 12:40 PM
id10t's Avatar
The jacks come w/ a little tool... if you have a few to do, skip buying - if you have lots to do, buy the tool. You may want a crimper for making patch cables.
Old 04-09-2011, 12:44 PM
slodave's Avatar
You can always think outside of the box too. I've come up with many little punch tools in a pinch.
Old 04-09-2011, 01:01 PM
AutoBahned
RWebb's Avatar
ok, solved - UNFORTUNATELY.... question #2
when do I use T568A vs. B ???
the wire pinouts differ for green and orange
from some stuff I searched up, I just need to be consistent (on the ends of each cable) but using "A" is best - true?
Old 04-09-2011, 01:16 PM
For Data, always use B.
Shouldn't need a tool if you buy a 10 pack of jacks.
Always use machine made cables, and only punch down jacks, don't get a crimper and make your own cables.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 04-09-2011, 01:25 PM
TheMentat's Avatar
An old credit card will work in a pinch.
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 04-09-2011, 01:41 PM
I've used a one sided razor blade to punch down Cat 6 into a phone box, worked good.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 04-09-2011, 02:35 PM
I make all my own cables, patch cords - everything in my home and work network. I use the B standard but have always heard it really doesn't matter - ends just have to match.
I found the 3 piece ends with the little slip on collar work well. I use a stripping tool and crimping tool from the Depot that works very well. For punching down into a phone jack I also use a cheap tool from HD that works great.
Just finished installing about 14 cat-6 ends last couple of weeks.
Best tip I found is to strip about 2.5 inches of casing as it makes the unwinding and straightening of the wires much easier. Get them in the right order and perfectly straight and flat and your connections will work great the first time.
Wish I could report that I never cut off a freshly installed end but we all make mistakes.
Randy
'87 911 Targa
'17 Macan GTS
Old 04-09-2011, 03:27 PM
AutoBahned
RWebb's Avatar
here is one thing I found re A vs B
T568A and T568B Wiring Schemes -- What's the Difference? - Control Cable, Inc.
nobody sez why...
Old 04-09-2011, 03:28 PM
AutoBahned
RWebb's Avatar
some sources say A cables can be connected to B cables; but others say you need a crossover cable to do it...
Old 04-09-2011, 03:35 PM
As long as the jacks are the same on both ends and the cables are the same on both ends, then yeah, it'll work. The way the pairs are set up on B is theoretically slightly better at high speed, but it's nothing tangible enough to matter in a home network.
But since 99% of all pre-made cables you buy are 568B, why not just be consistent.
Rob
Old 04-09-2011, 04:14 PM
Why would you make patch cords? It's cheaper to buy them. (machine made and tested)
You only punch down jacks and patch panels, 110 tool is all you need.
Don't untwist to much, just enough to punch it down.
If you are stuck and have to put a connector on a cable. There are two types of connectors one for stranded cable and one for solid cable.
1987 Carrera
Old 04-09-2011, 04:48 PM
AutoBahned
RWebb's Avatar
B it is - thx
Old 04-09-2011, 05:19 PM
When you are pulling cables for a network, I can't imagine trying to do it with a connector on the end. Now for a standard 3-6' patch cord - pre-made are great. But when you have a box of wire and ends - you make your own.
Randy
'87 911 Targa
'17 Macan GTS
Old 04-09-2011, 05:38 PM
Yep, and you keep doing that until the 3rd or 4th time one of your employees does a couple with slightly crossed pins that mess up a whole network and take forever to troubleshoot.
After that, everytime you see a homemade cable you cut it in half and chuck it. Same for any pre-made cable that's even remotely questionable.
Jacks/ Patch Panels are different, they go together different mechanically and are much harder to screw up.
If you want it to work reliably, the first time, and over time, you pull the fixed wiring (often solid), to patch panels or keystone jacks on the ends, and use pre-made cables (stranded) for the final 3-10', or more if that's what it takes.
So not saying *you* can't do them successfully. But that's why I never recommend it.
Rob
Old 04-09-2011, 06:04 PM
And the suppliers say there's less signal loss using solid cable (for interior wall connections) compared to stranded cable which is usually used for patch cables. That right? How critical? I need a total length of about 100 feet, about 25' of which runs through wall cavities. Can I run stranded patch cables all the way through with shielded Cat6 inline keystone connectors or is that 25' length critical enough to warrant solid cable for that stretch?
Sorry for the high jack, but I thought perhaps related.
Sherwood
Old 04-09-2011, 11:59 PM
