| AutoBahned |
				CAT 6 DIY - punchdown tool needed?
			do I need to buy a punchdown tool to install the connectors onto CAT-6 cable? if not, any suggestions for the best way to do it for a secure install? the connectors are RJ-45 IIRC... | ||
|  04-09-2011, 11:35 AM |
| RETIRED |
				__________________ 1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel | ||
|  04-09-2011, 11:40 AM |
| Registered Join Date: Mar 2003
			The jacks come w/ a little tool...  if you have a few to do, skip buying - if you have lots to do, buy the tool.  You may want a crimper for making patch cables.
				__________________ “IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” | ||
|  04-09-2011, 11:44 AM |
| Registered |
			You can always think outside of the box too. I've come up with many little punch tools in a pinch.
				__________________ Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD | ||
|  04-09-2011, 12:01 PM |
| AutoBahned |
			ok, solved - UNFORTUNATELY.... question #2 when do I use T568A vs. B ??? the wire pinouts differ for green and orange from some stuff I searched up, I just need to be consistent (on the ends of each cable) but using "A" is best - true? Last edited by RWebb; 04-09-2011 at 12:18 PM.. | ||
|  04-09-2011, 12:16 PM |
| Registered Join Date: Nov 2003 Location: Seattle
			For Data, always use B. Shouldn't need a tool if you buy a 10 pack of jacks. Always use machine made cables, and only punch down jacks, don't get a crimper and make your own cables.
				__________________ Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P | ||
|  04-09-2011, 12:25 PM |
| Registered |
			An old credit card will work in a pinch.
				__________________ Silver '88 RoW Carrera Grey '06 A4 Avant | ||
|  04-09-2011, 12:41 PM |
| Registered |
			I've used a one sided razor blade to punch down Cat 6 into a phone box, worked good.
				__________________ Rick 93 968 (My summer car), 05 Cayenne S (My winter car), 79 924 (Wife's summer car), 02 C230k (Wife's winter car), | ||
|  04-09-2011, 01:35 PM |
| Registered |
			I make all my own cables, patch cords - everything in my home and work network.  I use the B standard but have always heard it really doesn't matter - ends just have to match. I found the 3 piece ends with the little slip on collar work well. I use a stripping tool and crimping tool from the Depot that works very well. For punching down into a phone jack I also use a cheap tool from HD that works great. Just finished installing about 14 cat-6 ends last couple of weeks. Best tip I found is to strip about 2.5 inches of casing as it makes the unwinding and straightening of the wires much easier. Get them in the right order and perfectly straight and flat and your connections will work great the first time. Wish I could report that I never cut off a freshly installed end but we all make mistakes.
				__________________ Randy '87 911 Targa '17 Macan GTS | ||
|  04-09-2011, 02:27 PM |
| AutoBahned |
			here is one thing I found re A vs B T568A and T568B Wiring Schemes -- What's the Difference? - Control Cable, Inc. nobody sez why... | ||
|  04-09-2011, 02:28 PM |
| AutoBahned |
			some sources say A cables can be connected to B cables; but others say you need a crossover cable to do it...
|  04-09-2011, 02:35 PM |
			As long as the jacks are the same on both ends and the cables are the same on both ends, then yeah, it'll work. The way the pairs are set up on B is theoretically slightly better at high speed, but it's nothing tangible enough to matter in a home network. But since 99% of all pre-made cables you buy are 568B, why not just be consistent.
|  04-09-2011, 03:14 PM |
| Registered Join Date: Oct 2006 Location: So-Cal
			Why would you make patch cords? It's cheaper to buy them. (machine made and tested) You only punch down jacks and patch panels, 110 tool is all you need. Don't untwist to much, just enough to punch it down. If you are stuck and have to put a connector on a cable. There are two types of connectors one for stranded cable and one for solid cable.
				__________________ 1987 Carrera | ||
|  04-09-2011, 03:48 PM |
| AutoBahned |
			B it is - thx
|  04-09-2011, 04:19 PM |
| Registered | When you are pulling cables for a network, I can't imagine trying to do it with a connector on the end. Now for a standard 3-6' patch cord - pre-made are great. But when you have a box of wire and ends - you make your own.
|  04-09-2011, 04:38 PM |
				 | Quote:
 After that, everytime you see a homemade cable you cut it in half and chuck it. Same for any pre-made cable that's even remotely questionable. Jacks/ Patch Panels are different, they go together different mechanically and are much harder to screw up. If you want it to work reliably, the first time, and over time, you pull the fixed wiring (often solid), to patch panels or keystone jacks on the ends, and use pre-made cables (stranded) for the final 3-10', or more if that's what it takes. So not saying *you* can't do them successfully.  But that's why I never recommend it.
|  04-09-2011, 05:04 PM |
| Registered Join Date: Jul 2000 Location: So. Calif.
				 | Quote:
 Sorry for the high jack, but I thought perhaps related. Sherwood | ||
|  04-09-2011, 10:59 PM |
