Painting house, question on blue tape, green, or ornage tape?
Everyone is saying blue tape blue tape all the tie and I have been using since the beginning, over 20 os them. They are pain in the A. Most of the time it won't stick and frustrated me so bad, especially on tiles and new paint. It's only ok with clean old paint. I know the white tape will leave residue and it'll kill you when it come to clean up time. How about the green and orange tape? Are they stronger and won't leave residue? Which one is better for my case?
Thanks.
Fat butt 911, 1987 |
Green for door frames, orange for windows, blue for everything else...
The blue painter's tape comes in different stickiness... You sure you're just not buying the weakest? You've gotta look at the inside of the roll (maybe the plastic wrap). There will be a scale..
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 09-12-2010 at 11:34 PM.. |
really? I didn't there are different scale of stickness. I just grab a bunch of 1.5" 3M everytime I walk to the paint dept. I'll look next time. Thanks.
3M US: Scotch-Blue
I know there's more than two.. But you have to look. ![]() BTW, green is for rough surfaces...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Thanks Slodave.
- do green and orange leave residue? Anyone know? - Why not use the highest adhesive level? What is the draw back? Thanks.
Fat butt 911, 1987 Last edited by rnln; 09-13-2010 at 01:59 AM.. |
Better to just paint without tape. In half the time it takes to tape a room you will get so good that you can't tell the difference. Just go slow and steady to start with. Of course if you have the DT's or Parkinsons this may not be such a good idea. jmho
Bill B. 63 Little B Coupe 67 SWB 3.63 Hotrod 08 Cayenne S 65 F100 |
Certified User
"Ornage" sounds the most expensive - I'd use that!
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
I've been frustrated by the seeming high prices of the painter's tape the last coupe of years. I used to keep nearly a dozen rolls on hand (we've done a LOT of room painting over the years), but now when I go to the Lowe's/HD I find myself knee-jerking when I see the prices and running away and NOT buying until I absolutely need it. I mean COME ON, $6 a roll?!?!?
But I've also been wondering about the green tape.... The blue tape gives me more bleed under than I think it should, even when I use a rubber roller to set the tape line. When I tape something and then peel it up later I want to see a laser line on that paint.
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
When you remove the tape you want the surface you taped to stay put. Reduced sticky means you can tape a fresh surface sooner after painting.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
I used green "Frog" tape on the last house I painted the interior on (our rental). It was ridiculously expensive but it worked REALLY well. This house has light beige walls, white ceiling and white baseboard/woodwork. On this paint job, I did try to do more work without tape. In alot of places, I did a really terrific job, it looks like a pro did it. Other places, well, let's just say I spent far more time cleaning up my mistakes than I would have ever spent taping it off...
Tape is the friend of the infrequent painter. ![]() angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Hint for you guys looking for a really crisp edge in tight technical spot... Go to the autoparts store and buy the blue 3M tape that auto painters use. Its vinyl based and works around corners much better. Expensive tho.
Parrothead member
I'm also of the "no tape culture". With a little practice, you will be amazed at how good you get. I agree abut the price of tape nowadays. It's disgusting. Masking tape used to dirt cheap. I blame the influx of DYI tv shows. The people on those shows use tape like its nothng.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
A pro painter told me the best, fastest way to paint a room: 1) cut in around ceiling, don't worry about overlapping onto the wall a bit. Do NOT lose time being fussy. Then roll ceiling 2) paint trim around windows & doors. Focus on good coverage & keeping a wet edge. Overlap onto walls a *wee* bit... again, no extra points for painting in the lines. 3) Cut in wall color along ceiling, doors & windows. This is when you take your time & be fussy. By ONLY cutting in the wall color, no tape should be necessary... cutting in against the ceiling & trim is easy to do freehand. When finished, roll on wall color
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
The new Frog tapes do work well but they have very low adhesion.
Less adhesion is so the tape doesn't pull off the paint underneath it. You can use regular masking tape as long as you tape, paint and remove within a few hours. As mentioned, the standard stuff will likely remove the existing paint, so do a test first. But, here is the answer you are looking for, the secret to perfectly masked lines. This tip works anytime you are using 2 paint colors. Walls to ceiling, walls to accent colored walls, walls to painted trim or stained trim. 1. Paint first color. 2. Let dry overnight if possible. 3. Mask off newly painted surface using 3M 2080 Blue. 4. Take a very small amount of paint, the color you just used and paint the edge of the tape. You only want to use enough paint to seal the edge. The paint will bleed under the tape a little bit but that is ok since it is the same paint which is already applied. 5. Wait a half hour or so. 6. Now you can use you favorite applicator to paint the 2nd color. The new paint cannot bleed under the tape because you sealed it. 7. As soon as you are finished painting, gently remove the tape. Do not wait overnight or for the paint to dry. You now have a perfectly masked line.
Randy '87 911 Targa '17 Macan GTS |
Of course you don't need to use tape, but when you do, follow the above tip.
I used to:
Remove baseboards -> go crazy painting -> paint baseboards while they're off -> use air nailer to quickly reattach baseboards -> putty and touch up holes, and recaulk. Now since I can tape off the top of the baseboards quickly I Tape baseboards, go crazy painting -> remove tape -> paint baseboards (no tape)
'87 924S (Sold) |
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
![]() ![]() ![]() You can see in 2nd from the top, light blue line in the 2nd picture, where I didn't use this technique. I got a decent amount of bleed through. At this point, I had already painted the stripes twice and worn a hole through my jeans, from doing the knee shufflle around the room laying tape. Also - see my comment above about Frog tape. Not worth the money at all in my opinion.
Josh 85 M491 Coupe - "Fat Bastard" |
The 2080 blue tape just doesn't stick well on fresh paint and other stuff such as tiles. Today, while spraying, I realized that 3 or 4 of my new tiles are painted white because I have been spraying on them whitout knowing. The tape blew away. Arg..
If I remember what I read the other day, the orange and green are better suited to tile and brick, blue will do exactly as you found out. Using the stickiest tape on paint can result in ripping the paint and older layers off when removing the tape...
