B58/732
If something lizard-like climbs out of your leg and starts singing "Hello My Baby", you might want to see a doctor.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
winter-hater club member
duct tape.... huh. we use a shaving razor. the blade would pull the spines out.
i am glad to hear that the agave wound is resolving. that looks painful!
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
GAFB
Oblique Spaceballs reference win. 2 points.
Several BMWs |
Ahhh ha. I knew I remembered that scene, but I did not remember the movie. That is a great movie!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Control Group
Have to reiterate the warm moist compress, will help it to drain. If you want to get ambitious, you can do a Koch-Mason dressing. Moist cloth over wound, cover with dry towel, then wrap up with saran wrap. As the moisture is drawn into the dry towel, it will wick the nastiness out of the wound, saran wrap holds in the heat and cooks any bacteria that may be trying to set up a homestead. Not too tight, leave it wrapped up for at least a few hours, if it starts hurting more instead of less, take it off.
She was the kindest person I ever met |
1.367m later
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
AutoBahned
Control Group
Keep in mind that whatever moist cloth you put against that thing is very likely to soak up some very foul crap that will stain it forever. If you use a good washcloth and your wife tries to kill you don't go pointing any fingers at me.
Here are some instructions on the web I found that are wrong. The why it works is right, but I have found it to work better with the saran wrap on the outside, over the dry towel. I absolutely would not do a Koch Mason with a heating pad on top of it. It will get plenty warm without it. This was dreamed up prior to saran wrap being invented BTW. Surgeonsblog: Hot Stuff
She was the kindest person I ever met Last edited by Tobra; 10-21-2010 at 04:42 PM.. |
Formerly reformed
I accidentally stuck a 1.5" Prickly Pear spine into a vein on top of my left hand two weeks ago; made it all the way to the base of the needle and wiggled it around a bit. It bruised pretty bad (go figure) but healed within a few days.
1968 911P (Paperweight) |
