GAFB
What's the deal with the briquettes? I usually use the standard Kingsford lumps. I tried some of the fancy Cowboy charcoal - both lump and 'natural', and didn't like it. Burns too hot/fast for smoking. I get 3+ hrs out of Kingsford, easy. What are you using that you get 6? What quantity - one full chimney? Inquiring minds.
Several BMWs |
not as smart as I think
Kingsford is what I use, what ever is cheapest (Costco has 2 twenty lb bags for $15.00). I have no problem on the Q with my briquettes, but the smoker is a different story.
With regards to opening it, I don't do that often. I am constantly shoving briquettes under the smoker into the pan (there is just enough space for tongs and one briquette). I do open for mopping though if I am making pulled pork. I like to create a dark bark, that does happen every hour.
1978 911SC stock-SOLD 1985 911 Carrera Stock |
thanks buddy! i use some kingford..i swear it says extended burn on the bag. but i could be suffering from smoke inhalation. i get six. when i fire up the chimney, i dump the coals before all the coals are ignited. they end up at the bottom and light up later..i am speculating here, tho. i get six hours. someone invent a nice R2-D2 shaped asbestos insulating blanket, and it would change everything.
poof! gone |
The thread that Milt pointed me to included many useful mods for the smoker. One of them included adding air flow to the briquette pan by drilling holes in it.
My webber has a lot of vents in it that allow me to control the burn of the briquettes better. I believe this greatly aids in keeping my q going as well as it does when compared to the smoker.
Steve,
We've been using one of these for a couple of years now. Works great, easy to use and clean up. We really like it for seafood but have done a bunch of different things on it that all turn out great. When you're done just put it in the dishwasher. Easy to experiment with different types of wood too. Highly recommend it. Camerons Professional Cookware
'87 911 Coupe '95 911 Coupe '04 911 GT3 '98 Jeep Wrangler |
A Man of Wealth and Taste
While U Boyz are dickin around with these flimsy units trying to make em work I am chowing down on some serious Cue. Put this rack on about 2:15 and by bout 6 the big piece was tender enugh to fall off the bone when bitten into. Has a nice grilled flavor as it is smoked over a direct fire, the meat was not over smoked but had that subtle flavor. I used some Jim Beam Bourbon Barrel chips soaked for an hour in water before tossing them on the fire.
I use nothing but Mesquite or Oak Hardwood Lump Charcoal and when I want to really get down I use various varieties of Hardwood Logs burned down to glowing coals in the Klose unit. I guess U Boyz will continue to screw around with this junk until one day you wake up and say enugh of this BS. Then you will find it is so much easier, and you can then concentrate on the variety of rubs, brine's and slathers to put on the meat. U also have to remember each unit hs its own larning curve so the quicker U git to it the better...after all you only have so long to live. BTW I find if U keep the lid down you turn out a better product. You don't lose the consistency of a steady heat. So keep it to a minimum by keeping your fingers off the lid.
Copyright "Some Observer" Last edited by tabs; 11-01-2010 at 11:41 AM.. |
U Boyz can also look at it this way, by using a better unit you can turn out Professional BBQ that is equal to or better than most restaurants. U will find that U don't go to BBQ joints no moe, so look at all the money U is gona be savin by doin it yo self. And these things will last a life time and then some.
Copyright "Some Observer" Last edited by tabs; 11-01-2010 at 11:48 AM.. |
Here's a diagram of a brick smoker I built with a neighbor. We tore the thermostat out of an old gas oven and the build is really simple.
Wood sits in a huge cast iron skillet over a gas burner. Temperature control is absolute and dead simple. If you set it at 225, it stays there. The smoke travels across the box and exits on the opposite side. This smoker produces the best smoked meats I've ever eaten. The key is absolute temperature control. The heat source doesn't seem to matter. When the wood is burning hot, the gas isn't even on. As the fire cools, the gas will start to keep the temps up.
Wow, not sure if that was constructive tabs, but if I use that logic, how much does a professional rig cost? How many times can I eat out for that money ? How many times can I screw up with my own rig? Learning curve included, I may actually learn how to smoke (less involvement, similar taste) on mine in that time.
On rubs, mops, marinades and finishing sauces, those get consideration as well. Moses, thanks for the picture.
Steve, in post #24 you mentioned "briquettes." Now I don't BBQ nearly as much as I used to, but I always found a real charcoal fire to be better in terms of heat and length of burn. Are you using briquettes or charcoal? Is charcoal available like it used to be?
Milt, I apologize, I use the terms interchangably. I mean Kingsford branded charcoal briquettes. It is the cheapest stuff I can find (have a hard time spending money on something I am going to burn). I have used lump charcoal before, but never in my smoker.
I may have to change my tune with regards to the smoker and try something with more substance. I will check out a bbq store and see what they have there before my next outing.
You may like what real charcoal does, but use less because you really do get more heat out of less. When it burns to white ash, there is still a red hot fire down in the middle. Leave it alone for a long burn or stir it up for another round of burgers if you're cooking.
U might say I have become a Professional BBQer since I hve sold my product. Now let me give U a little lecture. Go to the best you can afford on your budget. That Terracotta pot idea is clean. I started BBQing back in 76 on a $2.50 Hibache ..Country style ribs marinated in KinKoman Terrayki Marinade. Served with Felbro Sweet Sour sauce. Still usin that Kikoman stuff for steaks etc My next move was to a Weber Smokey Joe for $25, and then the Webber Kettlefor $39, I am still usin that unit I bought 30 years ago this comin March (later I bought the Roterseri for it). Finally the Charcoal grid is starting to burn out. Then I moved to a Brinkman Water Smoker and then to a 35 gallon Drum that was bought way down on Century Blvd for $115. That unit did some fantastic Cue..but the bottom finally rust out. Then I went to a Brnkman verticle Bandera for $260 from Wally World, problem with that unit was the metal was too thin and I had to keep fighting the temp.(sold it for $175) I twas then that I broke down and went to the Big Green Egg for $678 and then I said what the fk and spent 2k on the Klose Drum wt 1/4 inch steel plate and 1/2 on the fire box..shiping was $500 of that cost as it weighs 600lbs..Now I got the pinnacle and there is no more to buy. I am set for life and it now comes down to talent. I once even found a Weber Kettle in the trash and took it home, sold it for $15. If U look around maybe you can find one on the cheap. Problem wt Mosae unit is if he moves he ain't takin it wid him...and yeah bricks will hold the heat like a mther fker and that is da key..heat retention.
Copyright "Some Observer" Last edited by tabs; 11-01-2010 at 01:28 PM.. |
Ohh yeah one of the bestest BBQ joints I have ever bin in is in San Brodue...on Baseline.. Bobby Raes...back in 82 he did the US Festival. He uses Stater Brothers Charcoal. He also buys his Texas sausage from the Gonzales Market in Texas. Everything he does in homemade the Potato Salad is to die for. At Bobby Raes the Lineolem floor is so old it is worn out, and the white folk generally sit in the back room.
Another great BBQ place is Pecos Bills in Burbank, they use a brick cue to do Okie style pulled pork ad ribs. The place is take out only, and I have seen Master Bedroom closets bigger. Every Saturday they sell out by 2 in the afternoon. They have bin in biz since the 30's. Personally I now use notin but Lump Hardwood Charcoal in 40 lb bags discounted down ifn you buy 5 bags to 12 bux a bag. I also can buy all the diff hardwood logs from him as well. He ships his stuff as far away as Maryland. The RIO here in LV uses his Olive wood for their cue a cord a week.
Copyright "Some Observer" Last edited by tabs; 11-01-2010 at 01:57 PM.. |
I agree with milt. Good lump charcoal will burn hotter, longer, and cleaner with less ash. So will burned down hardwood logs like tabs mentioned.
Personally, I don't have a whole lot of choice around here (NJ) but I am able to find Royal Oak, and Wegmans also sells good lump charcoal (though I have read that it is just rebranded Royal Oak) IMO, cowboy is crap...I'd sooner use kingsford than Cowboy. Check this link out if you're going to be shopping around. I find the reviews and rating to be accurate and helpful. The Lump Charcoal Database Rankings-- Naked Whiz Charcoal Ceramic Cooking As others have said, wood chunks are the way to go...chips are junk. I soak chunks and wrap them in aluminum foil, poke a few holes and then put it on. It will last longer this way (usually for a couple hours.) I do this on both my offset charcoal smoker and electric water smoker. Also, if you have trouble locating wood (again, limited in my area, especially during the winter) these guys will ship you some different kinds of wood for a reasonable price. Afterburner Additionally, those with thin-walled electric water smokers may benifit from using a fire blanket to insulate the smoker, available online or at local hardware/fire supply stores for $20-30...I find that mine doesn't have enough BTU's to actually work as designed if there is significant wind or cooler temps. I wrap the fire blanket loosely around the outside and temps are much more consistent, and you can regulate the heat with the lid vents, etc. as the unit was designed for. I've never had a problem with too much heat or any issues with the fire blanket...this might not be a good idea for a charcoal smoker, given the higher heat/flame that can be developed near the bottom. Again, please remember that nothing is fire proof, so if you do decide to do this please use your brain and keep an eye on things... ![]() ...Not that anyone would ever think of leaving a smoker unattended anyway ![]()
-Matt 1985 Targa |
Henry Ford was the guy who invented Charcoal Briquettes back inthe 20's. He took all the scrap wood from his auto factory and made it into those little briquettes. That ishow the Kingsford co got started.
Copyright "Some Observer" |
lump charcoal burns longer?
not so sure about that.. « Briquettes vs. Lump Charcoal i'm lucky, i work near LAZZARI. they probably make some of the best lump fuel around. we can take a yard garbage can, and they will fill it up. last time it cost me $30, if i remember correctly. about a 50% savings from buying the same stuff from a store.
poof! gone |
Vash, I am just down in San Jose (if I recall correctly, you are in The City). Where is Lazzari? I may have to check it out.
tabs I have the webber kettle, as well as the lil' joe and the smokey joe. I use them all. I have smoked in the kettle before but was given the Brinkman as a gift a number of years ago and I wanted to make it work more easily on the cheap. That did not work. Such is life. Mschuep I will spend sometime reviewing the information you linked to. I appreciate the idea of a fire blanket too. To all, thanks for the resources for good charcoal. I will put that information to good use. There is something very zen about smoking with wood. I will get an electric smoker soon, but that is really as a way to help my wife around the house with the cooking. Now, we can put food in a slow cooker before work and have it done when we get home, and that is great, occasionally. Now if I can add another arrow to the quiver, and while not attaining the zen state of wood smoking, offer another alternative for dinner, all is good.
AutoBahned
the Kingsford plant is right here - basically, they take sawdust from the mill waste pile, add glue and press it together
I either make my own charcoal (!); use propane, or buy real charcoal I never ever use Briquettes - just like the guy who worked in a pickle factory won't eat pickles... |
