Senior Advisor
James Brown's Avatar
Cessna bans ethanol fuel from all it's aircraft
Service letter SNL10-5 (yeah May, just slow here) states that after testing ethanol based fuels, they are not a alternative for 100LL fuel. In fact they say that operational safety may be compromised by the use of ethanol based fuels.
Now that ALL fuel in Washington State, as with many states, where do you guys get auto fuel for your STC approved aircraft that DOES NOT contain ethanol?
Cessna tests reveal the ethanol eats seals, gaskets, O-rings, increases internal wear on fuel pumps, corrodes ferrous compounds, forms salt deposits on screens, dissolves large quantities of water in the fuel system compromising fuel quantity indications.
If they don't like it, I don't like it. (E-10 in my car now)
08 Cayenne Turbo
Old 11-02-2010, 03:44 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Sounds like you need to use 100LL.
Old 11-02-2010, 03:46 PM
MAGA
Tim Hancock's Avatar
Ethanol makes my blood boil (and can help cause gas to boil in some aviation applications causing vapor lock). For many years I enjoyed filling my airplane with car gas from my 300 gallon storage tank. A couple years ago, the distributor who delivers my gasoline informed me that he could no longer buy non ethanol containing fuel here in Ohio. I do not fly nearly as much anymore as I have to pay up to $5/gallon for Avgas now. On top of that, the Enviro wackos have forced the gasoline producers to add in some really awful additives to car gas that results in horrible deterioration after only a couple months. In the past three years I have dealt with at least 10 cases of clogged pilot jets in carburetors of seasonal use engines. Back in the 80's and 90's, I did not have these problems in the same vehicles.
Stabil will not necessarily help anymore.... Just this year, I have resorted to draining nearly all my seasonal use items (multiple dirt bikes, street bikes, cars, snowmobiles, chainsaws, weed eaters, generator, pumps, lawnmowers, tractors, bobcat, jet skis, etc) and refilling with very expensive Avgas then running each unit to insure that the fuel systems are primed with the long lasting non gumming Avgas.
I keep hoping enough people will figure out that the current crop of ethanol plants are financially non viable without govt subsidies and demand change, but I am not holding my breath.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 11-02-2010, 05:46 PM
Feelin' Solexy
Tishabet's Avatar
The antique car guys are up in arms about ethanol creating vapor lock problems in warm driving conditions and eating up pump components etc which are not designed for anything but gas. I know some guys who have been cutting their gas with kerosene just to try to get the vapor potential down... what a pain. I finally broke down (quite literally, several times) this summer and installed an in-line pushing electric fuel pump in my Buick.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 11-02-2010, 05:50 PM
pwd72s's Avatar
Ethanol raising havoc with marine engines as well. IIRC, Oregon allows exemptions for Marine engines and AvGas...also non ethanol racing fuels are still available. All expensive.
Agreed, ethanol is a giant fraud foisted on an ignorant public...
(edit) 2 stoke engines also suffer with ethanol...my logger friend buys race gas to mix with 2 stroke oil for his chain saws.
Old 11-02-2010, 06:54 PM
Unconstitutional Patriot
turbo6bar's Avatar
What happened to the guy who planned to write an Iphone app pinpointing gas stations selling ethanol-free gasoline?
Old 11-02-2010, 07:08 PM
Zeke's Avatar
Sounds like a conspiracy to get rid of old cars on the road. But I sure don't want planes falling on me. I get a few dozen a day. don't up the chances.
Old 11-02-2010, 07:11 PM
I'd really like to know when I'm getting ethanol; I started having problems with vapor lock on my VWs this summer. I've never had it before.
Old 11-02-2010, 07:26 PM
The usual creep of lobbyists and special interests. It was supposed to be a cold weather substitute for MBTE - or what ever that nasty ground water polluting chemical was.. And that for EPA designated counties with winter air pollution problems. It may actually have some use - somewhere..
Now it is in all street gas - all the time.
That would have got away with it, until the pushed that E-85 **** onto us. Then it was revealed to be the great ethanol scam.
Another taxpayer funded boondoggle - propped up by consumers.
Old 11-02-2010, 07:39 PM
Non Compos Mentis
My airplane sees nothing but 100LL. The 911 sits for most of the winter, so I usually store it with 100LL. Just found out there is a local off-brand gas station near me that sells alcohol-free gas. I'm going to fill the 911 pretty soon and suspend insurance coverage for a couple months.
Old 11-02-2010, 07:46 PM
In OK you can still get the real deal... And all the stations are marked as to what they are selling! The only thing I run E10 in is the Corolla... It can't be killed after all....
Old 11-02-2010, 09:03 PM
canna change law physics
red-beard's Avatar
How possible is it to turn some of these small planes into turbo props?
James
Red-beard for President, 2020
Old 11-02-2010, 09:06 PM
Run smooth, run fast
Heel n Toe's Avatar
Look on the gas pump for stickers like this:
You're probably getting 10% ethanol almost every time you buy gas. I'm pretty sure the seller is required to display the stickers.
- John
Old 11-02-2010, 09:43 PM
Senior Advisor
Small turboprops are around $100k range and go up from there. The problem is none of these aircraft are certified to have a turboprop installed unless there is an STC issued by the FAA and I know of only one company that makes turboprop conversions for a Cessna 172/182. And there charging BIG bucks for it. You can make your aircraft experimental and try any engine you want but you can never switch back. My choice for aircraft in the future is a Piper Malibu Meridian.
08 Cayenne Turbo
Old 11-02-2010, 09:58 PM
You do not have permissi
john70t's Avatar
Shucks, for pilots there's no harm in a vapor lock or twwwwwwwwwww...........
Old 11-02-2010, 10:55 PM
MAGA
The scariest vapor lock scenario is landing somewhere on a hot summer day then departing a short time later after the engine compartment is totally heat soaked. Moments later while climbing out (low and slow) over a densely populated area the d@mn thing quits and you end up going down into multistory apt buildings.
0% Liberal
Old 11-03-2010, 05:13 AM
Bill is Dead.
cashflyer's Avatar
I'm glad to see that Cessna is making it an official statement, and I expect the FAA will come out with similar notices soon. Too many people think "gas is gas".
I just lost a fuel pump to crappy gas in my seasonal car, and had not thought about Tim's solution. I will drain it and run some avgas next time. Now that cold weather is getting near, I should do that with my mower and weedeater too.
Old 11-03-2010, 06:11 AM
red-beard's Avatar
The engine or a whole aircraft for $100K
The Briggs and Stratton engine seems to be OK with the Ethanol. But both of my Honda engines and my Dad's Pressure washer as not working right. They all need new carburetors.
James
Old 11-03-2010, 06:15 AM
Parrothead member
VINMAN's Avatar
Huge problem for the boating community. Alot of boats have F/G fuel tanks, and the ethanol is dissolving the gelcoat and the tanks are literally falling apart. Plus it is destroying the rest of the fuel system.
I had the replace all the fuel lines and seals on my Waverunner last yr, they turned to mush. The pickup lines in the tank actually fell apart and stranded me.
Vinny
Old 11-03-2010, 06:22 AM
I remember when Bush decided to go 10% ethanol to help corn farmers (and likely his distiller friends) while also reducing our dependence on foreign oil by 10% - all I was thinking was "but what about the old carbureted stuff!"
Old 11-03-2010, 06:26 AM
