Shaun @ Tru6's Avatar
Winterizing Ducati
Last year I drove the bike pretty late in the season and early next. This year I'm putting it away early and will most likely be taking it out late. Storing in heated space.
What's the best way to keep fuel and carbs clean? Fill tank and add Stabil? or empty tank to dry? anything else to consider?
Tru6 Restoration & Design
Old 11-03-2010, 09:59 AM
Drain the tank and the carbs. Stabil doesn't helpas much with the crap that passes for gasoline these days, especially if you are afflicted with gas containing ethanol.
The usual other things apply; fresh oil change, make sure other fluids are within time/age parameters, tires inflated to max sidewall pressure (or lifted from the ground) intake and exhaust corked, bike clean and paint waxed, battery removed and stored on a battery tender, etc.
JR
Old 11-03-2010, 10:09 AM
Man thats a lotta work.... Glad I live where I can just play with my toys year round.....
Old 11-03-2010, 10:16 AM
Friend of Warren
I agree with JR, best thing to do is drain the tank and carbs. The drain the oil and refill with new.
Kurt V
Old 11-03-2010, 10:22 AM
Driver
Noah930's Avatar
I used to fill the tank and add Stabil. Ran the motor for a few minutes just make sure the carbs were filled with the mixture, as well. I didn't want to leave the tank empty, for fear of rust forming on the inside. Take that for whatever it's worth.
I also fogged the cylinders with a couple cc's of motor oil, then turned the crank to try to get it to coat the bores. I would spray/wipe metal parts (frame, bolts) with WD40 to try to prevent rust, as well. The one winter I didn't do it in New England, I wound up with a dusting or rust in a couple places.
I changed the oil with some cheapo stuff, then changed it again in the spring with good stuff. That might have been overkill. But I never left the previous season's oil sitting over the winter.
Otherwise, like javadog recommended: Covered the intakes and muffler tip with a plastic bag to keep rodents out. I didn't always have wheel stands, so I hyperinflated the tires to prevent flat-spotting. Battery was removed and kept on a trickle charger.
1990 Black 964 C2 Targa
Old 11-03-2010, 10:33 AM
Dang.....you guys do a lot. I generally fill the tank full (if metal....so no rust), inflate the tires, put the gals on a trickle, throw a cover over them and go skiing. There are days even in winter where we will see mid 50's so they usually see some kind of use during Dec - March.
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 11-03-2010, 10:40 AM
In FL. Winterizing is putting on long sleeves
Old 11-03-2010, 10:41 AM
greglepore's Avatar
Specific to a 900ss-Shaun, look at the lower corners of the tank-they are below the pump intake. Any water will find its way down there, and the tank WILL rust out, ask me how I know....fixed mine with marine tank epoxy, but would prefer you not have to.
If you are storing the bike, I'd run her dry, then remove the tank and drain it by turning it upside down, then check for rust and if lucky, POR it. Or jsut buy a carbon tank
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 11-03-2010, 10:44 AM
MAGA
Tim Hancock's Avatar
I have probably 50 internal combustion engines. For years, I would simply park the vehicle indoors and shut the gas petcock off. If I thought of it, I might charge the battery once or twice and run the engine until it was hot....
Never had a problem until the last few years when the gas formulation began clogging pilot jets solid. Tried Stabil, but it is not 100%. Now I am draining/siphoning all my gas and replacing with $$$$ Avgas to avoid the mandatory carb teardowns each spring/fall. Effing enviro-nazi govt fuel additive regulations.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 11-03-2010, 10:52 AM
Driver
Noah930's Avatar
An option to POR is a product called Kreem. Three-part process of cleaning the tank with an acid solution, then a rinse, and finally a coating for the inside of it. Then you can store it dry without fear of rust. Just don't plug the vent hole with the final coating step.
Tim and Java have good points on the use of Stabil. My advice is based upon what I did when I last lived in New England, three years ago. If gasoline formulation has changed since then, perhaps Stabil is no longer the way to go.
Old 11-03-2010, 10:55 AM
I'll take 8 months of riding in the Colorado Rockies vs. your 12 mos with roads that put you to sleep
Old 11-03-2010, 11:01 AM
I see you
flatbutt's Avatar
I change out the motor oil, fill the tank and stabilize it, trickle it and start drinking. If I had carbs I'd drain the bowls for sure.
Old 11-03-2010, 11:15 AM
Thank you Gentlemen! Will get this done this weekend, going to turn in the plates tomorrow. Bike will be object #3 for the crane. Casters have been ordered, going to start making the base this weekend. Should be able to really go through the bike this winter here at work.
Old 11-03-2010, 11:18 AM
Slackerous Maximus
HardDrive's Avatar
I'll just fill the tank, put it on front and rear stand, and leave it on a trickle charger. Here in Seattle, we do get the ocassional sunny, dry day in the winter, and I'll take the bike out and run it around the neighborhood until its at up to operating temp.
I've never used stabil. Are there any potential downsides to it?
2014 Cayman S, PDK
Old 11-03-2010, 11:25 AM
greglepore's Avatar
Ditto on the bad fuel=my injected bikes were fine, but my son's VFR will clog jets in a month or two if not run-modern fuel is evil...
Greg Lepore
85 Targa
Old 11-03-2010, 11:56 AM
Not really, unless you consider the false confidence it gives you. I used to use it every winter; I even still have several bottles of it on the shelf. I just found that the gas that evaporated in the carb float bowls left a nasty residue, Stabil or not, and I got sick of cleaning carbs every spring.
The gas we have today is crap. I wouldn't store it for more than 30 days. Race gas lasts much longer, certainly long enough to last a winter.
I figure that if there's no gas in something, it can't evaporate and cause me any problems. I don't get tank rust, as my garage is heated and very dry.
JR
Old 11-03-2010, 12:05 PM
MAGA
I never used to use it, but I did add some to some vehicles last year. I cannot truly say whether it works to prevent varnish with the new problematic fuels as I ran alll the vehicles several times which in theory would have circulated/stirred the fuel enough in the carbs to minimize varnish accumulation.
I simply cannot say whether the "old Stabil" which definitely helped keep older formulations of gas "fresh" will stop the new formulation from developing deposits in carbs. I am not willing to experiment anymore as tearing a bunch of carbs down every season just is not cutting it for me anymore. For now I will simply stick with doing the Avgas swap.
0% Liberal
Old 11-03-2010, 12:07 PM
least common denominator
scottmandue's Avatar
Crate up the Duc and ship it to San Pedro Calif., I'll park it inside and take it for rides on the weekend to keep the battery charged up for ya.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-03-2010, 12:17 PM
I'll get it in here and have them stop in SP before going on to Thailand.
Old 11-03-2010, 12:55 PM
