-   -   12 pt. vs. 6 pt. sockets - Which is BETTER? (http://forums.pelicanparts.com/off-topic-discussions/573363-12-pt-vs-6-pt-sockets-better.html)
Racerbvd 11-03-2010 02:59 PM
You need a 12 point for BBS bolts:D
http://forums.pelicanparts.com/uploa...1288821551.jpg
Rusty Heap 11-03-2010 03:01 PM
PB Blaster is your friend.
but when that fails, speak softly but carry big tools:
I own full sets of 1/4, 3/8th, 1/2, and 3/4 of both 6 and 12 point.
21 Piece Metric 3/4" Jumbo Heavy Duty Socket Set
8 Piece 3/4" Drive Heavy Duty Metric Impact Socket Set
3/4" Heavy Duty Impact Wrench
This set up to 24" long fits both standard AND metric.
http://www.harborfreight.com/15-inch-18-inch-and-24-inch-jumbo-adjustable-wrenches-751.html
Joe Bob 11-03-2010 03:03 PM
Dremel.....
scottmandue 11-03-2010 03:17 PM
I just butter my nuts and don't worry about it.
Zeke 11-03-2010 03:18 PM
Originally Posted by turbo6bar (Post 5653197)
I was given one of those for Christmas last year. I haven't seen it since. So I went out to the tool box and there it was, front and center. Looks goofy to me.
I guess after 10 months I'll try it.
on2wheels52 11-03-2010 03:21 PM
Buy 6 point sockets, 12 point wrenches.
Jim
porsche4life 11-03-2010 03:25 PM
Snow tires.....
RedBaron 11-03-2010 03:29 PM
12 Point if the bolt is tough to get to.
6 Point for normal use. I mostly use a 6 point and I always use it when I am torquing a bolt because a 12 point is more likely to strip it.
Shaun @ Tru6 11-03-2010 03:53 PM
BFH
and so that this thread is not a total waste
http://forums.pelicanparts.com/uploa...1288824803.jpg
sammyg2 11-03-2010 06:18 PM
And there ain't nuthin better than kroil.
GWN7 11-03-2010 06:34 PM
Generally 12 points are thinner wall sockets than 6 point. Therefore subject to more breakage.
VaSteve 11-03-2010 06:35 PM
How much torque are you putting on the bolts?
I typically go for the 12 points first because nothing is ever easy to get to.
MBAtarga 11-03-2010 07:24 PM
Try the home brew concoction of Acetone and ATF, mixed 50/50.
jyl 11-03-2010 07:57 PM
If the ratchet on your socket wrench isn't ridiculously coarse, there's no advantage to 12 pt. For close end wrenches, I like 12 pt.
Scuba Steve 11-03-2010 08:19 PM
Originally Posted by Hugh R (Post 5653209)
After you've rounded off the bolt, or nut, go to Sears and get their "Bolt out" sockets (as advertised on TV by Bob Veila). They have internal biting teeth and are really good at getting rounded nuts and bolts off.
Seconded - it's an awesome tool. Those totally saved me when I did a timing belt / water pump job on the wife's car. Steel hardware + aluminum block = all kinds of fun.
Schumi 11-03-2010 08:21 PM
12 point would only be used for 'external triple square threads' as they are referred to by the DIN.
Otherwise 6 point for any normal hex. Old 12 points will round corners off too easily.
When working on formula cars, 12 points were not allowed to be used on NAS hardware, ever.
cmccuist 11-03-2010 08:57 PM
360 / 12 = 30 deg. 360 / 6 = 60 deg.
You only need 12 point if your ratchet or breaker bar can't make that swing.
Only communists and welfare recipients use 12 point. :p
sammyg2 11-03-2010 09:26 PM
Color me skeptical.
1990C4S 11-04-2010 04:11 AM
Originally Posted by sammyg2 (Post 5654016)
Color me skeptical.
It works.
GH85Carrera 11-04-2010 05:31 AM
I have both. I use them where appropriate.
