-   -   12 pt. vs. 6 pt. sockets - Which is BETTER? (http://forums.pelicanparts.com/off-topic-discussions/573363-12-pt-vs-6-pt-sockets-better.html)
RWebb 11-03-2010 01:52 PM
now that the mid--term elections are over (and the transmission gear lube thread seems to be winding down), I thought a rousing debate on sockets would be appropriate.
have at it...
Tobra 11-03-2010 01:53 PM
6 point
Superman 11-03-2010 01:54 PM
6 point
M.D. Holloway 11-03-2010 01:56 PM
4 point...
dhoward 11-03-2010 01:59 PM
Two three-point.
red-beard 11-03-2010 02:00 PM
I like screw drivers and hammers
Paul_Heery 11-03-2010 02:01 PM
6 point, they get a better grip on your nuts.
RWebb 11-03-2010 02:02 PM
I see the write in candidates are doing better than the 12 pt.s and that the 6 pt.s have quickly surged into an early lead...
What are the political advantages of the 6 pt. socket?
Scott R 11-03-2010 02:08 PM
Depends on the job. Exhaust manifolds on a Land Rover requires a 12 point, tie rods I would use a six.
URY914 11-03-2010 02:14 PM
Split the difference and try a 9 point.
cbush 11-03-2010 02:25 PM
Guess 12 points would be better for tight areas, but I always use 6 point when I can--much better grip/torque transfer to the nut-in my opinion.
VaSteve 11-03-2010 02:27 PM
Those spiral rusty nut extractors.
dafischer 11-03-2010 02:27 PM
Vice Grips!!
A930Rocket 11-03-2010 02:28 PM
6 point is the way to go, but why do I have so many 12 point?
Zeke 11-03-2010 02:33 PM
It shouldn't matter. But, if your nuts aren't in good shape, they may slip.
turbo6bar 11-03-2010 02:41 PM
You losers stay in the 80s with your rack of sockets. Gator grips changed my life.
http://forums.pelicanparts.com/uploa...1288820354.jpg
sammyg2 11-03-2010 02:43 PM
If the bolt or nut is a standard hex, a 6 point socket will get a better grip and transfer more torque than a 12 point, especially if the head is rusted or partially stripped or whatever. The 12 point is more convenient as it can go on indexed many different ways.
Iffn the head is made for a 12 point (as in many aircraft fasteners or some header bolts) then you have to use a 12 point.
I prefer 12 point on smaller sizes, like 1/4" drive and smaller 3/8" drive.
For the larger 3/8" drive sockets and all 1/2" and 3/4" drive, 6 point is the way to go.
And all sockets that will be used on an impact gun should be 6 point, hardened, heavy duty and designed for impacts or they'll eventually crack and can cause injury.
JJ 911SC 11-03-2010 02:44 PM
Used a 12 points to removed a broken wheel lock nut... work like a charm :):):)
sammyg2 11-03-2010 02:45 PM
Those are loosers, not losers.
Or maybe they are tighters.
Either way I've been turning wrenches too long and I'm too set in my ways to go for those new-fangled gimmicks.
Hugh R 11-03-2010 02:45 PM
After you've rounded off the bolt, or nut, go to Sears and get their "Bolt out" sockets (as advertised on TV by Bob Veila). They have internal biting teeth and are really good at getting rounded nuts and bolts off.
