Registered Usurper
DARISC's Avatar
Need advice on buying a scanner
Any recommendations on what 11 x 17 flat bed scanner to buy to scan artwork? I'm looking to spend in the neighborhood of $300. I don't want/need any bells and whistles or bundled image manipulation software.
'82 SC RoW coupe
Old 11-04-2010, 11:13 AM
The Unsettler
stomachmonkey's Avatar
Man back in the day I could have told you more than a person needs to know.
I don't think I've actually used a scanner in years.
The UMAX scanners were great back in the day.
I noticed that by and large they have become cheap and light. As in a lot of the metal parts have been replaced by plastic which has a reduced life span.
Interested to see the responses here.
"I want my two dollars"
"Brandon Won"
Old 11-04-2010, 11:16 AM
Epson makes some good scanners as well.
Old 11-04-2010, 11:34 AM
I service scanners, Kodak, Fujitsu, HP, mostly high speeds.
There are no good 11x17 flatbeds for under 300. Mustek ScanExpress or the A3 at Newegg.com
is the closest I can think of. Good Luck with this
Old 11-04-2010, 11:50 AM
Eric Coffey's Avatar
+1
Look at their "Perfection" line (V700 & V750).
Old 11-04-2010, 12:18 PM
id10t's Avatar
Consider the possibility of a mount for a digital camera w/ good lighting.... we rigged one up to "scan" some prints, taking the photos was much easier than doing it w/ scanner...
Old 11-04-2010, 12:28 PM
Registered Usurper
DARISC's Avatar
Great! What better source of info than from one who services them?
I tossed out the $300 figure, aware that it might be wishful thinking.
The A3 looks like it would fit the bill. What would be your pick for a "good" scanner If I spend say, up to $400?
It won't be used in any kind of production scenario, so I don't care about speed (if that's a factor, re price). I'm an artist and wil be using it to eventually scan hundreds of drawings dating back years, after which it will be used only occasionally.
Thanks!
'82 SC RoW coupe
Old 11-04-2010, 12:48 PM
Registered Usurper
DARISC's Avatar
Originally Posted by Eric Coffey View Post
+1
Nice, but I want 11x17 capability.
That's what I've been doing using my old Cannon SD450, but I can't leave the setup and positioning/keeping flat the widely varying sizes of the drawings makes it a hassle even with the setup. I'd like to be able to just put a drawing on the scanner, flatten it with the lid and press the button whenever I want.
'82 SC RoW coupe
Old 11-04-2010, 01:12 PM
I really do not have much to do with the smaller scanners, the scanners I service are very expensive, high speed production type scanners. The flatbeds I do service are the Fujitsu's
and their 11 X 17 is $$$$. That Mustek A3 is the closest I can find that meets your needs.
Old 11-04-2010, 01:34 PM
I'm betting that 11x17 is not cheap. That's double the size of 99% of the consumer models.
You may want to consider a good 8.5x11 and then stitching the images together.
Old 11-04-2010, 01:50 PM
If you check out B&H Photo, and do a search for 11x17 scanner, the cheapest one listed is $1000, and most are +$2k
11x17 scanner
Old 11-04-2010, 01:53 PM
If you go to Google or Amazon, there are a few low end cosumer grade parts that are <$500. How often are you going to need to scan something that large?
Old 11-04-2010, 01:55 PM
Registered Usurper
DARISC's Avatar
...That Mustek A3 is the closest I can find that meets your needs.
Just pulled the trigger on one at Newegg.
Thousand Shermans (many tanks! ), youse guys!
'82 SC RoW coupe
Old 11-04-2010, 02:12 PM
Registered Usurper
DARISC's Avatar
...How often are you going to need to scan something that large?
The many sketches, drawings, etc. are of varying sizes and aspect ratios, quite a few 11x17 or larger, so I'll still be doing some stitching.
'82 SC RoW coupe
Old 11-04-2010, 02:17 PM
Registered Usurper
DARISC's Avatar
Recieved my Mustek A3 2400 PRO this afternoon - had it up and running in 20 min. Sure seems to fit the bill so far.
'82 SC RoW coupe
Old 11-05-2010, 07:57 PM
