Originally Posted by VINMAN View Post
Is that a laden or unladen stuntman?.... About three fitty.....
African or European?
Old 11-12-2010, 10:50 AM
"lb" is not a unit of force .....
"lb" is a unit of mass. Force is mass x acceleration ( F = m *a ) and the unit of force is "lb * ft / sec^2". When we use "pounds" as a shorthand expression for force, we are implicitly leaving out the relevant acceleration..
Actually, you're both correct.
a slug is the Imperial unit of mass.
The slug is a unit of mass associated with Imperial units. It is a mass that accelerates by 1 ft/sec2 when a force of one pound-force (lbf) is exerted on it. Therefore a slug has a mass of 32.17405 pound-mass or
Also, in certain cases there is "Pound-mass" lbm and "Pound-force" lbf.
A pound-force is the amount of force required to accelerate a slug at a rate of 1 ft/s2
Old 11-12-2010, 11:02 AM
[QUOTE=jyl;5670003My copy of Halliday & Resnick is falling apart so badly that I need to buy a new one.[/QUOTE]
I can sell you mine. 1981 edition. Dog hasn't chewed it yet.
JR
Old 11-12-2010, 11:11 AM
jyl jyl is online now
jyl's Avatar
Interesting, I never heard of "slugs" as a unit of mass. I'm guessing that is more of an engineer's term, and also that engineers are more likely to refer to force in "pounds".
I am more literal-minded. force = mass x acceleration, so for me the clearest unit to use for force is kg * meter / sec^2 (Newton) or lb * ft / sec^2.
Old 11-12-2010, 11:28 AM
Page 64 in Halliday & Resnick...
It's a British thing. I never could figure out why they couldn't use "our" system, or the much better metric one. They always have to do something different....
JR
Old 11-12-2010, 11:34 AM
A pound is not mass.
Period, end of story.
A kilogram is mass. A kilogram times a meter is a Newton, which is force. A Newton of force applied to wrench one meter long produces a newton-meter of torque.
That same torque is 0.738 pound-foots, which is the same as 0.738 pounds of force applied to a wrench a foot long.
Pounds are force, as are newtons. When you're in space, your "weight" is zero pounds. Your MASS does not change.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 11-12-2010, 02:44 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Just use Mexican stuntmen and you won't have to worry worry about OSHA or anything else for that matter...
Michael D. Holloway
https://5thorderindustry.com/
Old 11-12-2010, 03:13 PM
jyl's Avatar
You're referring to pound-force (448 Newtons) rather than pound-mass (0.434 kg).
Pound -- from Eric Weisstein's World of Physics
To avoid the confusion between pound-mass and pound-force, maybe we should redo the calculation in metric units. I get the force on the pulley is 1986.85 Newtons, and the minimum rated load for the platform 202.53 kg, which is 467 lb (pound-mass) w/ rounding. The combined mass of the three stuntmen is 227.85 kg.
Old 11-12-2010, 03:25 PM
I much prefer metric units for this sort of thing.
Old 11-12-2010, 04:57 PM
i'm just a cook
onlycafe's Avatar
JR
whitworth.
Old 11-12-2010, 09:00 PM
David's Avatar
It seems to me the bigger issue with OSHA is life lines and their connection points have to be able to handle 5000 lbs. I've looked this up on the OSHA site a few times trying to find out their exact definition of a 5000 lb rating and haven't found it. So I've taken it to mean 5000 lbs to bring the support to yield stress although I try to have safety factor of at least 3 if possible.
Old 11-13-2010, 07:00 AM
