Incorrect pinion depth setting, I once ruined a rear end by not crushing the collar correctly. It was not in a semi though.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Unregistered
That's an easy one. Take a look at the damage on the ring gear. No where near where the load is supposed to be.
Something got distorted or out of whack to the point were the load was no longer transferred to the center of the gear where it belonged, instead it was transferred to the edges of the teeth where it shouldn't be. The failure did not start with the gears, they are the result and not the cause. My bet is either a bearing let go or some other mechanical failure which resulted in a significant misalignment of the gear mesh. |
Alii&Maui
The rear tandem lost traction while the front took the full force of the load. The drivetrain wound up, unwound, would up again then BLAMO!
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Targa, Panamera Turbo
Wow - you guys are good! Two camps here: 1) Driver Abuse 2) Bad Set-up
Very good! Now, if you believe it is one, prove the other wrong and if two wrong prove the one wrong! I am of the belief that it is both 1 & 2! (but not the gear oil!!!)
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Really hard to tell from the pictures.
I've seen some idiots trying to slide their trailer tandems and it's a wonder the driveshaft doesn't get bent like a pretzel let alone what it does to the rear end and U joints. I've never had a rear end fail. I replaced mine(2 years ago) at over a million miles because the nose bearing had loosened up enough (frt. rear) that i couldn't keep a seal in it. I wanted to change the ratio anyway so i swaped out both rears at the same time. If there was no flaw in the pinion i still say driver abuse.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey Last edited by pete3799; 11-13-2010 at 01:55 PM.. |
Senior Advisor
Kind of like aircraft accidents and fire investigations, I'm right because I said so and it's always pilot error.
08 Cayenne Turbo |
Alii&Maui
Naw, I wouldn't say driver abuse, I'd say rookie mistake.
Senior Member
Bad lubrication?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Bill is Dead.
Wheel hop and other driver mistakes usually damage the axle shafts, not the R&P.
Now if an axle snapped and loaded the diff with debris, you could have significant R&P damage. If the axles are not damaged, I say to check the R&P setup. Either it was a bad setup, or as speculated in another post, a pinion nut or bearing failed and allowed the pinion to drift out of proper mesh. Those are my guesses.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
