dewolf's Avatar
Oil Sludge question
Took the oil cap off the work hack today and noticed sludge on top of the rockers. It's an I6 Ford Australia motor. My question......best way to remove the sludge without pulling the motor apart? Friend reckons drain a liter of oil and drop a liter of engine degreaser in there and run it for about 20mins then drain. I think degreaser is quite combustible so not to sure about this idea. Any body got any suggestions?
Scott
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 11-16-2010, 02:10 AM
wdfifteen's Avatar
That cure may be worse than the problem.
You don't want to loosen that stuff up with the engine running, if it makes it past the oil pickup screen without clogging it up, the nasty crap will go to filter and clog it, when the filter goes to bypass the crap goes straight to the bearings. Myself, I'd take the pan off and clean it out and make sure the return oil passages from the head are clear. Put in new oil and new filter, change the oil and filter after a few miles of driving.
Old 11-16-2010, 04:02 AM
I would use an additive, run the engine and then drain the oil. But only as a last resort.
Old 11-16-2010, 04:18 AM
hardflex's Avatar
I'd just put synthetic oil in and change the filter in a couple thousand miles.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 11-16-2010, 05:52 AM
Unregistered
sammyg2's Avatar
Agreed. Just because the commercials that sell oil and additives say that a little sludge build up will hurt your engine does not make it true. These are the same folks that say you need to change your oil and filter every 3000 miles, which we all know is BS.
Just run a synthetic oil and change it again after a short time.
Old 11-16-2010, 06:32 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
The synthetic oil you should run in it should be ester based not PAO based. The ester based oil will dissolve the deposits.
Where you are at I think you can get Motul 300V, a 100% Ester Based Racing Oil or Motul 8100 100% Ester Based Street Oil. Check this site. EuroSyntheticOils.com carry ELF and Motul Synthetic Lubricants.
Michael D. Holloway
https://5thorderindustry.com/
Old 11-16-2010, 08:37 AM
I've solved many a problems like this with a quart of marvels mystery oil. The only thing is that I don't know if you can find it in Australia. If not I suspect you can find a thin engine cleaning detergent oil similar to marvels.
Old 11-16-2010, 08:43 AM
Unregistered
sammyg2's Avatar
Oh, ya gots to be careful nowadays iffn you have a catalytic convertor.
Some stuff that used to get put in oil might destroy a cat now.
Old 11-16-2010, 10:07 AM
Old farmer fix was to add a quart of kerosene or #1 diesel fuel to the crankcase and let it idle for a few minutes before an oil change.
Old 11-16-2010, 10:28 AM
A little ATF works well too....
Old 11-16-2010, 10:33 AM
AutoBahned
RWebb's Avatar
Exactly.
don't use anything in the above posts yet - just change the oil and filter several times, running the car 100's or 2,000 miles each time until the oil appears clean - use a non-detergent or low detergent or mix of the two oils
THEN & ONLY THEN use an aggressive, get the sludge out technique.
Old 11-16-2010, 11:20 AM
I'd listen to Mike (Lubemaster) and Sammy. There are quart sized additives you can buy to add and run your engine only about a few minutes to clean the engine out. That sounds nice but I don't totally trust their claims. I would be afraid of chunks of gunk clogging up my filter with a quick treatment like that, if you truly have a significant amount of sludge in there. That would seem especially true with any treatment if you have a full flow filter on the engine, which is usually the case. If that kind of filter gets clogged from a large amount of sludge, just think of what can happen. I've seen filter canisters break from the pressure, not to mention what can happen inside the engine.
Marv Evans
'69 911E
Old 11-16-2010, 11:21 AM
if you put ATF or fuel in your crank you will f*** up your engine worse than a soup sandwich.
Michael D. Holloway
Old 11-16-2010, 12:29 PM
I don't think ATF or fuel have the lubricity needed to keep the bearings from overheating and spinning on the crank. At least marvels is designed to be installed in a crank case. Google: Marvels Mystery Oil or MMO and you'll see the product I am referencing.
Old 11-16-2010, 12:53 PM
AutoBahned
RWebb's Avatar
looks like you should add a soup sandwich to your oil; run it briefly and then drain
Old 11-16-2010, 12:59 PM
What type of soup do you use for the sandwich? Whole wheat or white bread?
Old 11-16-2010, 01:17 PM
AutoBahned
RWebb's Avatar
in your digestive system, fiber helps prevent problems
but in your car's oiling system, fiber can clog it up
Old 11-16-2010, 02:08 PM
buncha kunckleheads I tell you what...
Michael D. Holloway
Old 11-16-2010, 02:42 PM
Unregistered
sammyg2's Avatar
Yep.
uh-huh.
Yep.
Hey where's boomhauer?
Bobby! Get off the lawn with that bike!
Old 11-16-2010, 03:29 PM
dewolf's Avatar
Thanks for the replies gents, but engine is cactus. The oil galleys are full of sludge and the top end of the motor is dry. Took the rocker cover off and......holy crap.
Old 11-16-2010, 05:09 PM
