Used Up User
imcarthur's Avatar
M-Audio FastTrack Pro $199 USB & S/PDIF (ask for Trent)
or search used on Gearslutz (must log in though)
Ian
'87 Carrera Cab
Old 12-02-2010, 02:59 PM
AutoBahned
RWebb's Avatar
thanks - can I use the cheaper M-Audio items?
e.g. Fast Track USB for $120 (?)
BTW - Gearslutz does not seem to have any classifieds section or forum for posting gear for sale
Old 12-02-2010, 03:59 PM
Eric Coffey's Avatar
thx much Ian - I'll do just that if the M-audio, etc. is cheap enuff.
The M-Audio stuff is pretty decent from what I've heard. Looks like they also make a firewire version for the same price, and both are available cheaper thru Amazon:
Amazon.com: M-Audio Fast Track Pro 4x4 Mobile USB Audio/MIDI Interface with Preamps: Musical Instruments
Amazon.com: M-Audio Firewire Solo US35030 Firewire Audio Interface: Musical Instruments
I'd check out the TC and E-mu units as well (both feature up to 192khz sampling):
Amazon.com: TC Electronic Desktop Konnekt 6 24Bit/192kHz Firewire Desktop Audio Interface: Musical Instruments
Amazon.com: Creative Professional E-MU 0404 USB 2.0 - Sound card - 24-bit - 192 kHz - 117 dB SNR - stereo - Hi-Speed USB: Musical Instruments
And even more options still:
ESI - DuaFire
ESI - Product Archive
ESI - U24 XL
The other advantage for going with the software/systems I mentioned earlier is the great user support. They can tell you which interfaces/mics work best with each system, and have already tested most of them for quality/compatibility. Liberty Instruments (PRAXIS) even has a complete kit available.
Either way, if the trial versions of those programs will give you what you need, I'd probably go that route over a possibly less accurate/lower quality freeware offering.
Old 12-02-2010, 04:47 PM
Used Up User
imcarthur's Avatar
I really can't argue with this. I looked into the software I mentioned above & it uses a handheld spl meter as input, so that wont work - although it might be interesting to try it.
Ian
'87 Carrera Cab
Old 12-02-2010, 04:59 PM
