Evil Genius
Rusty Heap's Avatar
"Sir, your check engine light is on..."
Nice:
YouTube - Engine Explosion dyno room
Life is a big ocean to swim in.
Wag more, bark less.
Old 12-08-2010, 07:33 PM
Laneco's Avatar
Ewww.... That was expensive. Bet it was really, really LOUD too!
angela
Hello
Old 12-08-2010, 07:36 PM
Detached Member
Hugh R's Avatar
Wow, they should have used that BG System of engine lubes that guarantees against engine failure.
Hugh
Old 12-08-2010, 07:41 PM
pwd72s's Avatar
LOL! Good one...
Old 12-08-2010, 07:44 PM
Burn the fire.
Brando's Avatar
Built Ford Toueeeerrrrrrrr-wooops...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-08-2010, 08:00 PM
Did you get the memo?
onewhippedpuppy's Avatar
Motor Meister?
‘07 Mazda RX8-8
Old 12-08-2010, 08:14 PM
crustychief's Avatar
runaway diesel?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 12-08-2010, 08:58 PM
19 years and 17k posts...
azasadny's Avatar
Ouch!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 12-09-2010, 04:20 AM
"YOU CANT RACE A CAB."
ODDJOB UNO's Avatar
welcome to "ON-STAR", would you like a systems analysis update?
if there are TROUT..........there are BEARS!
Old 12-09-2010, 05:48 AM
Evil Genius
Rusty Heap's Avatar
after watching that many many times back to back, you can see a vertical linear bearing or pneumatic cylinder in the back ground that controls a water flow valve, engine isn't under any load till half way through the dyno run.
Most likely, this is a hydrostatic dyno where you put more and more load on it via the engine turning a water pump and you can vary the load this way (did some dyno work back in College with a beater 2 barrel carb'd Chevy 350 on a waterdyno) it took 8-10 horsepower just to idle the engine, keeping the piston mass/crank/oil pump/valve train resistance all spinning.
Note 1/2 way through the video, the vertical actuator in back drops, openning the water valve, engine reacts by torque rotation to the left, raising up on the right, and then the birthing process starts.
Yeah that was an ucking fugly way to kill an engine, and a big mess to clean up too with all the oil pouring out of the front of the pan at the end.
Old 12-09-2010, 09:33 AM
Still Doin Time
asphaltgambler's Avatar
For even "more better engine failures" - google -search or you tube pro stock or super stock diesel pulling tractors where they run as much as 100psi of boost or more and spin the engines three to four times the OE rev limit.
Man when those things blow - they REALLY blow
Old 12-09-2010, 09:47 AM
wdfifteen's Avatar
Interesting observations!
I worked at a GM lab that had 6 engine cells. Had to clean up after a number of failures. The worst was a 6.2 diesel driving a 700R4 that blew so spectacularly that initially we couldn't tell whether the engine or the trans had failed first. We used eddy current dynos with an inertia wheel so if something went bang it kept turning for a while and did lots of damage. Had some good times and interesting experiences in that lab.
Old 12-09-2010, 10:13 AM
This poor thing was put out of it's misery.
Old 12-09-2010, 04:42 PM
Virginia Rocks!
VaSteve's Avatar
Thanks for explaining that. You hear it start working at :24 with that whine...I wondered why it did that.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-09-2010, 05:37 PM
Almost Banned Once
sc_rufctr's Avatar
Excellent.... I liked how the guts fell out the bottom.
Almost looked liked a gutted animal
- Peter
Old 12-09-2010, 06:31 PM
Almost Banned Once
sc_rufctr's Avatar
This is good
- Peter
Old 12-09-2010, 06:40 PM
