Cablevision Question
In the attic there is a cable splitter. I believe it has 5 or 6 outputs. Can I come off one of those outputs with another splitter, say for 2 more outputs? Will it work or does Cox have to come out and "do what they do?"
You can always try it, as I think it will work.
What do you have? One cable home runned from the interface to the attic with a splitter at the end? And now you want to add more outlets, but have no more connections left on the original splitter? |
not as smart as I think
You can introduce a splitter. It will degrade the signal strength to each tv. If the runs are short enough, it should not prove to be a problem, but for longer runs, you will likely notice it.
1978 911SC stock-SOLD 1985 911 Carrera Stock |
The Unsettler
If you have an outlet nearby you can run inline signal boosters.
Also a good practice to terminate unused/open connections on the spliter |
In line signal boosters? Where would I find something like that. I did try it and didn't work.
Radio Shack, Home Depot, Lowes, they all have em & cable too.. stomachmonkey nailed it . I have done this with no problem and the booster is the key..
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
So at what point do they plug in at?
I am not sure I would recommend a booster. They will boost signal and noise.
Was the splitter of the correct frequency?
Insert Tag Line HERE.....
do you have cable internet? This is where you will notice a problem. I have 6 TVs and internet and after countless calls of slow erratic internet, they came out and had to run a special direct line to my modem and then split it off for the tvs.
Formerly reformed
Shouldn't be a problem with the internet if you run your network's modem from the first split rather than down the line.
1968 911P (Paperweight) |
Cable and Internet from Cox. We have cable to 3 bedrooms and the den but wanted to add it to one more room. My Internet is all wireless. Cox wants $90 to come do just one drop.
