jyl jyl is online now
jyl's Avatar
Free Mac OS X App To Invert Negative Images?
I'm looking for a free app for my Mac (PowerPC/Leopard) that will allow me to invert a negative image. I have some film negatives here, rather than do a traditional wet contact sheet, it would be easier to lay the negatives on the scanner and invert the image from negative to positive. But I don't want to buy an app just to do this. Is there anything?
Old 01-09-2011, 02:10 PM
maxnine11's Avatar
I'm not sure if this will work, but it's worth a try.
-Open image with "Preview"
(that is the default image viewer on your Mac)
-Click on "Tools" in the top bar
-Click "Adjust Color" in the drop down menu
-Slide the Black level all the way to the right
-Slide the White level all the way to the left
- let us know if it worked.
max
max
Old 01-09-2011, 02:29 PM
maxnine11's Avatar
Just thinking, your scanner software must have some settings.
See if you can scan your negative in 'negative' to get the desired result.
good luck.
max
Old 01-09-2011, 02:36 PM
jyl's Avatar
Thanks for the suggestions, max.
I tried reversing black and white levels in Preview, it doesn't work.
My scanner is a Brother MFP, the scanning software is minimal and lacks a "negative" setting or any image inversion.
I've also tried scanning via Mac OS X's Image Capture and that doesn't have image inversion either. iPhoto also lacks that feature.
I downloaded a trial version of PhotoEdit (Mien Software) but it says "out of memory or corrupt file" when trying to open the scanner file which is about 36MB at 600dpi. I guess I can keep reducing the resolution to get a file that it will open, but a 35mm neg scanned at 100dpi isn't going to be so useful.
Old 01-09-2011, 03:09 PM
id10t's Avatar
The Gimp (GIMP - The GNU Image Manipulation Program) can probably do it
Old 01-09-2011, 03:14 PM
Paul_Heery's Avatar
The Gimp will do what you want.
Open your original in The Gimp. From the menu, choose Color, then Invert. Save your modified image as a new file.
Old 01-09-2011, 03:34 PM
jyl's Avatar
Thank you, all! GIMP has inverted the image for me, I need to play w/ contrast etc to make it right but I can surely figure that out.
Old 01-09-2011, 05:45 PM
