Targa, Panamera Turbo
Petroleum Engineering Guys, I need a lil help plz...
There are some great prizes and gifts that await if I can get some info...
Any of you guys working at an oil refinery? I need some help. I am working on a piece and I need some real world information on the various tests performed on crude coming into the plant as well as the tests run during refining. Also, if any of you have any text books or the like on Petroleum Engineering, I would love to be able to borrow them for a month or so. I will pay for shipping as well as compensate you with some great prizes and gifts. I hope you can help me out. Thanks!
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Just ask any Congressman. Congress is all knowing about the entire refining business. They know way more than the companies that run the refineries.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Unregistered
I work at a refinery and the information you are asking for could fill a library or three.
Just testing the process stream products keeps about 16 chemists employed full time at this refinery. I've got lots of books but most are either company property, proprietary, or so egg head and specific they probably won't be of much use. One sitting on my desk right now is called "applied process design for chemical and petrochemical plants" volume 1. It tells you how to design and build process units and all the components and I use it all the time, but there are parts that even I can't figure out. It's deep. I remember reading a long time ago called "petroleum refining for the non-technical person". It's a very good book for general refining theory. If you could let us know exactly what you are after it could be easier to help. |
Agree, I was looking through all the ASTM tests related to crude oil and refining and there are a bunch. Generally speaking viscosity, sulphur and water content would be very important as well as some others. Those are the types of tests I am looking for as well as why they are important.
Specifically I am looking for the tests for the crude oil (the basic ones) as well as the in-prcocess tests run on the distillates primarlilly the bright stock and light oils - the middle distillate range. Any info on the QC/QA would be fantastic.
Somewhere in the Midwest
You might consider contacting an indepent lab. Try SPL. They have an office in your area probably.
I need an idea of the things that go on at the refinery.
Occam's Razor
It's all about the hydrocarbons. Broken down to the very basic function - you heat up crude, and you take your product. There are so many processes - hydro cracking, cat cracking, vacuum units, gas oil units, asphalt, sulphur removal...
But at it's core, a refinery turns crude into product - jet fuel, gasoline, kerosene, propane, butane, asphalt etc.
Craig '82 930, '16 Ram, '17 F150 |
Craig, yup, got that covered, what I was needing was the in situ (process) analysis of the material before, during and after for quality control / quality assurance.
Soukus, yup they could but I really need to know is the actual tests run during production for quality control / quality assurance.
Unregistered
That doesn't "make" anything, it simply seperates and sorts what is already there. The test for distillation is range and percentage of boiling points of the mixture. Organic chemistry tells us that everything is a mixture. Nearly all process streams have some sort of distillation. The second type of process is cracking or reforming. Using either temperature or catalyst (and sometimes hydrogen) to change the shape or size of the actual molecules. Then it goes to distillation. Third type of process stream is cleaning. Removing sulfur, ammonias, water, etc. Usually they use amine products to strip the bad stuff out. The tests for that is just to see how much of the bad crap is still left. Here's a little info from a company I worked for a few years ago: Quote:
Ag_Strip_Mod130 FIA_1319 MCRT_4530 Ox_Stab_525 TAN_1.doc Water_pH Alky_Acid Cloud_5773 Flash_56 (TCC) MDEA_H2O Pour_5949 Thiosulfate in Lean MDEA Water_TDS Aromatic_HPLC Color_1500 Flash_93 (PM) MDEA_SW_H2S RVP_5191 Viscosity_445 Water_Thio Aromatic/PAH_5186 Color_6045 Freeze_5972 Millipore_5452 S.A.F.E. Water_Tolerance_1094 Aromatic/Benzene_5580 Cu_Strip_130 FTNIR MTBE/ETOH_4815 Sediment_473 Water_Tot_Res_Chlorine Ash_482 DEA_HSS_H2O.doc GC_2163 Water_Cl Water_Sett_Solids Baume_223 DEA_SW_H2S.doc GC_MTI_2504_2163 N2_Antek9000_4629 SIMDIS_2887 Water_COD Water_Sulfide (H2S) Benzene/Aromatic_5580 _on_4815/5580_GC DEA_Thio.doc Gravity_4052 Soda Water_Content _Dist_95 Water_Susp_Solids BS&W_4007 DHA_Twin_6733 Gum_381 Octane_2699 Smoke_1322 Caustic Distillation_86 JFTOT_3241 Octane_2700 Sulfur_Antek9000_5453 Water_NH3_VACuttes Cetane_613 Doctor_4952 H2SinVaporSpace Olefin_6550 Sulfur_2622 Water_O&G WSIM D-3948 Electrical Conductivity_D2624 Sulfur_(Tracor)_4045 Last edited by sammyg2; 01-11-2011 at 10:12 AM.. |
Unregistered
BTW when we buy crude oil (we are independent so we don't pull it out of the ground) it comes with an assay report, basically listing all of it's physical characteristics.
We do take samples and test to verify that what we got was what we bought but most of the testing for crude is done long before we ever see it. |
This discussion is another reminder of the near-miracle it is that we have readily available fuel from coast to coast for a measly 3 bucks a gallon. Think of the effort and technology that's required from drilling to refining to delivery. It's capitalism at its finest.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
